Help Programming a PKE 94
Old Nov 8, 2001 | 08:48 PM
AlHale's Avatar
AlHale
Default Help Programming a PKE 94
Can;t find the manual..Help! How do you program a PKE?
Old Nov 8, 2001 | 09:20 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Default Re: Help Programming a PKE 94 (AlHale)
This is out of my 96 book but I think it is the same for all:
1. Move all transmitters out of range
2. Turn the ignition key on
3. Push TRIP ODO on the driver information center twice
4. Within 5 seconds, press and hold FUEL INFO until the PASSIVE KEYLESS ENTRY light comes on.
5. Turn the iginition off, but leave the key in the ignition. The PASSIVE KEYLESS ENTRY light should begin to flash to show the system is in the programing mode.
6. Bring on transmitter into range. The light will stop flashing and stay on to show that the code is stored.
7. Move the transmitter out of range. The light should start to flash again.
8. Repeat steps 6 and 7 with each additional transmitter.
Hope this helps.
Leo
Old Nov 8, 2001 | 10:14 PM
AlHale's Avatar
AlHale
Thanks!!!!
Worked like a charm!
I owe you one.
Al
To Help Programming a PKE 94
