Switching seats
Regards....SilverBullet
Seatback Removal
Remove or disconnect:
1. Seat cushion
2. Position seatback in upright position to remove tension from adjuster
3. Vacuum hoses from solenoid noting postion and tagging for later installation (sport seat)
4. Harness retainers (sport seat)
5. Seatback adjuster rear bolt
6. Pivot adjuster up and remove cable
7. Bolts, seatback hinge to cushion frame
8. Bolts, rear of seatback to seat adjusters
9. Seatback
Install or connect:
1. Seatback to seat cushion frame
2. Cable to adjuster with tab down
3. Bolts: hinge, seat adjuster and seatback adjuster
Tighten: Seatback hinge bolts to 10 N-m (89 lb. in.)
Seat to adjuster bolts to 27 N-m (20 lb. ft.)
Seatback adjuster rear bolt to 27 N-m (20 lb. ft.)
5. Hoses to solenoid (sport seat)
6. Seat cushion
I usually switch mine everytime I change my oil. That way I get an even amount of wear on each seat.
