brake replacement
Old Sep 9, 2007 | 10:48 PM
EMBPILOT's Avatar
EMBPILOT
Default brake replacement
I'm looking to do brakes on the 94, I just installed a clutch etc...and now have the itch to do the whole shootin' match on the car b4 cold wx comes in this fall. I don't need (means I can't afford) a whole new system but a good set of rotors and pads all around is probably in the budget. any suggestions? Also what are the thoughts on brake fluid flushes? its got 70,000mi on it
Old Sep 10, 2007 | 12:34 AM
jabez's Avatar
jabez
If you are just using your car as a daily driver you should just pick up low price Raybestos.
