P0300 code! Not finding help on Tech/Perf
Old Sep 11, 2007 | 08:58 AM
Klondike's Avatar
Klondike
Default P0300 code! Not finding help on Tech/Perf
Looks like I'll be needing an ignition diagram.(No, I don't have a manual yet) Anybody got a diagram appropriate for a 96 LT4 ignition that shows from the key switch to the plugs? The P0300 code says: multi misfires detected, but doesn't give any specific component to go after.
Car only has a little over 50k miles on it, but it is 11 years old now, and I'm thinking "dying Opti". I've checked for vacuum leaks and not found any. My A/C controller fix the day before is WAY too close for this to just be a coincidence. I'm thinking something on the edge of intermitten got disturbed under the dash. But now I have to find it
Old Sep 11, 2007 | 12:15 PM
pr1mu5's Avatar
pr1mu5
Sucks man... I hate that code. Probably of absolutely no help to you, but I had that code on my 96 Yukon.
I changed all the O2 sensors, the knock sensors, full tune up, replaced cats, distributor, ignition coil, some other stupid sensor (spark advance something or other, I forget) and I NEVER got rid of that code.
I sold the Yukon and bought a vette.
Old Sep 11, 2007 | 09:57 PM
Klondike's Avatar
Klondike
That's the main reason I shed myself of that damned old GT Mustang I had. It developed one of those "mistery" misfires. I changed the dist. coil, wires, plugs, harness, computer, ignition switch...everything on that car except the paint. I got to where I didn't want the stinkin' thing even if it ever did get fixed. Finally just changed the owner!
Old Sep 11, 2007 | 11:03 PM
Gary04Z06's Avatar
Gary04Z06
Have you changed the plugs or wires recently? I got that code a little while back after changing the plugs and wires. Turns out I switched the #1 and #3 plug wires , corrected them and car ran fine and code went away.
Old Sep 11, 2007 | 11:25 PM
corvette1989bham's Avatar
corvette1989bham
send me your email and I will email you the gm diagnostic tree (but you really need a scan tool)
corvette95@charter.net
Old Sep 12, 2007 | 07:54 AM
runner140*'s Avatar
runner140*
My only experience with a random misfire with code "was", two spark plug wires were touching metal parts and grounding out. I used zip ties to get the wires off metal parts and grounding.
Old Sep 14, 2007 | 08:53 AM
Klondike's Avatar
Klondike
Default Still Working on it.
I started under the hood by getting the air cleaner & mass Air off and out of my way. When I did that, I looked down into the mass air sensor, and the screen was full of bug wings and grass! I opened up the air cleaner box and found one corner of the K&N was not seated correctly and outside air was getting around it. Now I'm cleaning everything up and looking at all the connectors along the way too. I was cleaning up the throttle body which was filthy and noticed something stuck under the plate on top that says "Grand Sport". Well, there was a wrinkled up old gasket under there. I thought it was just a look pretty plate all this time. After finding two different part stores where the parts counter guys just stare back like deer in the headlights, I'm making a new gasket myself to put back in there. After I get all the cleaned air parts back on, I'm continuing my electrical tracing and do a fuel filter change as well. Everything I've touched so far has needed attention, so I'm touching everything I can get to. This might just be a stackup of many little things finally ganging up to make one big mess.
Old Sep 14, 2007 | 03:36 PM
wake's Avatar
wake
Check out the short harness run that goes from the opti to the passenger side valve cover area, near the injectors... Mine went bad on the 96 LT1 I previously owned and gave the same indications... P0300 was also one of the codes I recieved... Considering you're getting multiple misfires, I'd look either there, the coil or coil wiring, and maybe the opti itself...
The dealer replaced the opti under warranty before they found out it was a $30 harness causing the problem in my instance...
Old Sep 19, 2007 | 04:35 PM
Klondike's Avatar
Klondike
I've checked out all the wiring to the Opti & Ignition box and all had good connections thanks to GM's great weatherpack connectors. ( On my Fords, they couldn't have held water any better if they had put the connectors in a funnel!) The Opti is pretty nasty down there with lots of road grime mixed with a little oil that must be coming from either the front seal or the crank position sensor. The plug wires may have suffered because of that. I think if I have to do the wires I might as well pull the front of this thing off and do a new MSD Opti and fresh wires & plugs too. Still cleaning up the whole front of the engine. Man there sure is a lot of stuff crammed in there !
Old Sep 20, 2007 | 10:59 PM
Klondike's Avatar
Klondike
Default I've had it!
Finally got everything cleaned up and back together. Rode around the block and it's still screwed up. Well, it goes in the driveway now and the wifes car gets its spot in the garage. I spent 2 years on another car with this problem, nobody could fix it. I finally just sold it. I got so sick of looking at that bastard I didn't care if it ever ran or not. I can't see the worth of sheltering something that won't run. I'm sick & tired of throwing money at it, and wasting what little time I have left. Screw the damn thing! I'll park it under the tree and let the squirrels eat it! Maybe somebody will want it next spring when they're full of energy and enthusiasm.
Old Sep 20, 2007 | 11:04 PM
corvette1989bham
ok, sell it to me cheap right now...pm me how much
To P0300 code! Not finding help on Tech/Perf
