Automatic shifter button sticking?
Old Sep 11, 2007 | 03:37 PM
krex725's Avatar
krex725
Default Automatic shifter button sticking?
Thanks.
Old Sep 11, 2007 | 04:11 PM
Nzzz's Avatar
Nzzz
Did you take off the button and look in there with a flashlight to see if something is jammed? Maybe some WD-40 would loosen it up. Can't help much on this but just a idea.
Old Oct 16, 2007 | 11:03 AM
krex725's Avatar
krex725
Okay
Old Oct 16, 2007 | 04:35 PM
krex725's Avatar
krex725
Thanks.
Old Oct 16, 2007 | 07:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the WD-40 doen the shifter shaft doesn't free it up, remove the button, **** and console cover to access the shifter mechanism.
Then you can see if it's a mechanical failture or a simple cleaning & lube issue.
Old Oct 16, 2007 | 10:04 PM
aminnich's Avatar
aminnich
You don't need that solenoid. It is only on the 95 and 96 A4s and is a stupid, unnecessary piece of crap. Pop the solenoid off, disconnect the wire and no more problem. The ONLY difference is you will be able to depress the shifter button without having your foot on the brake, all other safety features will remain in tact.
ps--solenoid is down in the shifter housing, driver's side rear and just a ball and socket that pops right off. Of course you will have to pull the console cover again to get to it.
Old Oct 17, 2007 | 02:25 PM
krex725's Avatar
krex725
Thanks.
Old Oct 17, 2007 | 03:53 PM
Vettehappy's Avatar
Vettehappy
Just to let you know I had the same problem and removed the solenoid as suggested, easy job no issues. Plus it will only get harder as time goes on.
Old Oct 17, 2007 | 06:40 PM
krex725's Avatar
krex725
THanks.
Old Oct 17, 2007 | 06:52 PM
aminnich's Avatar
aminnich
Originally Posted by krex725
Sorry to sound so clueless, but what exactly does a solenoid look like? I did some Google searches but they apparently don't all look alike. I just want to make sure I'm extracting the right part!
This one looks more like a cylinder, about 3" long and 3/4" in diameter. It sits nearly vertical, left rear in the 'well' for the shifter mechanism. It is almost directly below the little light for your shift indicator. It has just one wire connection, is made out of plastic and if (big if) my memory is any good the body is black and the ends are white. Nothing fancy, it just pops off at both ends.
Old Oct 17, 2007 | 09:34 PM
krex725's Avatar
krex725
Old Oct 25, 2007 | 09:45 PM
krex725's Avatar
krex725
Old Oct 25, 2007 | 11:32 PM
comp's Avatar
comp
I finally had time last night to take apart the console again and try to yank this thing. It was exactly where you guys said it would be and after a few minutes of messing with it, it popped right off. The next morning it shifted like it was brand new. Hard to believe a simple fix was all I needed these past months of aggravation.
Thanks again for everyone's help!
Old May 3, 2014 | 11:53 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Did you lock the pin out of postion or re4move it? I have not looked at mine yet but not quite sure how to remove the cover, any suggestions or instructions.
Old May 3, 2014 | 02:22 PM
65Z01's Avatar
65Z01
All thanks to some wonderful "safety" engineering...
To Automatic shifter button sticking?
