1987 automatic door locks
Old Sep 19, 2007 | 09:20 PM
yellow87's Avatar
yellow87
Default 1987 automatic door locks
anyone know if you can disable the auto locks on a 87 convertible, every time i start the car it locks the doors?
Old Sep 19, 2007 | 09:24 PM
PAINTER MAN's Avatar
PAINTER MAN
That must be an after market item. The 87 didn't come with that feature.
Old Sep 19, 2007 | 10:22 PM
c4cruiser's Avatar
c4cruiser
Does the car have an aftermarket alarm system? Do you have a keyfob of some sort?
Old Sep 19, 2007 | 10:30 PM
The Beep's Avatar
The Beep
The locks work independently of the ignition. Must be either a short or a mod of some sort. I don't see why an alarm system would be wired that way.
Newer cars will lock the doors when you put it into gear but your saying they lock when you turn the key?
Also, have they always done this or did this just start happening?
Old Sep 20, 2007 | 01:10 PM
yellow87's Avatar
yellow87
It has an alarm system, however i don't belive it should be doing that. Basically i started the car and shut the door and as you guessed it locked me out. So not sure why its doing that maybe i will disable the alarm and it might be ok after that. \ and someone mentioned that 87 should not have auto door locks, maybe that the issue
Old Sep 20, 2007 | 01:15 PM
ITHZ's Avatar
ITHZ
My '87 does not do that.
DaleD's Avatar
DaleD
I have an 87, it only locks when I hit the button.
Old Sep 20, 2007 | 08:40 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I have an 88 with all options and it doesn't lock until I lock it
Old Sep 20, 2007 | 09:31 PM
Demonic85's Avatar
Demonic85
The only thing weird i've seen the locks do is cycle through as in lock then unlock but nothing like this. Sounds like the previous owner wired it up that way or something.
To 1987 automatic door locks
