hood help!!!!
Old Sep 24, 2007 | 09:54 AM
mike-ssi's Avatar
mike-ssi
Default hood help!!!!
good morning- i hope someone can help. the hood cable on my 90 c4 convertible has either streched out or snapped and i can't get the hood open to charge the battery (it's been sitting about 3 months). is there a manual or alternate release latch or another way to get it open? thanks for ANY help,
mike-ssi.
Old Sep 24, 2007 | 10:47 AM
Matatk's Avatar
Matatk
Mike -
This is pretty common, and the question comes up quite often. Unfortunately, there is not an alternate release. Many guys (myself included) have put in an "emergency release mod" which is essentially a couple of cables attached to the latch that you can get to near the wipers - but that won't help you now. There is a hood release tool that some guys have had success with, although it apparently takes some practice (I've never tried). I heard of one guy removing the plastic wheel housing and reaching up there and pulling on the latch, but that's also time consuming (again, I've never had to do it). Have you tried pushing down on the hood while pulling the handle and then getting it open? That's how my hood is, and I've never adjusted it. I just pop the lever, push down on the hood and then lift up. You might want to play with it a while. If you search the old posts you can probably find better info than I've given - I'm no expert.
Good luck,
Matthew
Old Sep 24, 2007 | 12:14 PM
staugur's Avatar
staugur
This is the tool but you can make one out of an old coathanger or something.It slips in under the hood from the back over the top hinge and the idea is to hook the little latch and release the hood. If you can look at another vette and see what you're trying to do it makes it a lot simpler.
Old Sep 24, 2007 | 12:45 PM
HG's Avatar
HG
Two more thing to try, first, have someone grasp the hood and shake it from side to side as you pull the release. Or, pull the release handle and try to grasp the wire with a vice grip and pull just a bit more. These were two suggestions I read in Corvette Fever magazine. Good luck.
Old Sep 24, 2007 | 12:54 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
You Can Try This, And Good Luck.
Take Coat Hanger And Bend It To A Loop, Than Slip The Hanger From The Windshield Area Under The Seal, And Sort Of Fish For The Latch Carefully, You Might Be Surprised Cause That Is How I Got My Hood Open With No Damage, Not Even To The Seal. I Won't Tell You How Long It Took, But Gm Service Manager Was The One That Told Me What I Just Told You. Ok, It Took Less 5 Minutes If You Need To Know.
Like I Said, Good Luck!
Old Sep 24, 2007 | 06:43 PM
ecorse66's Avatar
ecorse66
What is the diameter of the rod? It looks like about 1/4 inch.
Old Sep 25, 2007 | 12:34 AM
staugur's Avatar
staugur
about 3/16"
Old Sep 25, 2007 | 01:53 AM
jabez's Avatar
jabez
Make sure the hood is aligned when you closed it the previous time. Push down over the latches of the hood and try release again.
Old Sep 25, 2007 | 08:12 AM
Da Mail Man's Avatar
Da Mail Man
...after you get the hood open......go to this link and read post #5
http://forums.corvetteforum.com/show....php?t=1372483
Old Sep 25, 2007 | 12:20 PM
mike-ssi's Avatar
mike-ssi
Hi Matthew-
thanks for the post. ecklers has a tool for this-probably the same one in the picture- for $20 plus another $15 to ship it. i'll let you know how it turns out. i was born & raised in brookfield and lived in riverside before i moved to saint simons island in southeast georgia. just curious- what suburb are you in?
thanks again,
mike.
Old Sep 25, 2007 | 12:38 PM
mike-ssi's Avatar
mike-ssi
Default thanks for all the responses!!!!
i'm sort of new to the forum- this is my second post- but it's amazing the help and responses i've gotten- thanks to everyone for the input!
best regards,
mike.
Old Sep 25, 2007 | 03:16 PM
runner140*'s Avatar
runner140*
So this doesn't happen again, look at this:[IMG][/IMG]Its a zip tie.
Old Sep 25, 2007 | 03:51 PM
staugur's Avatar
staugur
Don't waste money on the tool just bend some wire up.Looking at the photo you need to go in to the right of where the hood catch would be and snag the bare wire that operates the catch and pull backwards.It should pop.Having said that ,no one has suggested first taking a pair of pliers to the cable where it goes into the hood release catch(by your left knee) and giving it a tug.If it's just loose and not broken that often works.Good luck.
Old Sep 25, 2007 | 06:03 PM
Da Mail Man
see post 9 as zip ties will eventually become brittle and break and you will be no further ahead then when you started......either way will work though.....
Old Sep 25, 2007 | 06:16 PM
mike-ssi's Avatar
mike-ssi
Default zip tie fix
thanks again for all the responses!
the zip tie looks like a great idea. as for turning brittle, use black ties. they will last a lot longer since they're made to take the heat and even hold up better under sunlight and UV rays.
Old Sep 25, 2007 | 06:34 PM
Da Mail Man
.....zip ties don't take the heat or the weather although the whites last a bit longer....the wire will never break, is impervious to the weather and is encased in tubing to sheild from rust....(and you can encase the wire in any colored tubing ya want...
To hood help!!!!
