Brake Problems
Old Sep 28, 2007 | 07:22 PM
kclark85's Avatar
kclark85
Default Brake Problems
I was out driving and all of the sudden my brakes almost completely stopped working, they still stop but the pedal is way down. I checked the fluid it isn't low, it looks like it needs to be changed though. I was thinking it might be the master cylinder?
Old Sep 28, 2007 | 08:30 PM
Kinkajou's Avatar
Kinkajou
Wow, so this keeps repeating to corvette owners everywhere and the only thing I usually hear is:
Soft Pedal = master cylinder
Hard Pedal = Booster
Problem is that changing master cylinder, flushing, new pads etc has not helped. Problem always finds the way back.
Hope you find a solution to your problem soon.
I have found that flushing the system works a little on my car.
Old Sep 28, 2007 | 08:35 PM
mdlfcrss's Avatar
mdlfcrss
If the master cylinder is full (which means no leaks in the system), the master would be the logical assumption if it's a spongy pedal. I'm not quite sure on any adjustments in the rear calipers that would cause a low pedal, maybe someone else might know the answer to that. Good luck...
Old Sep 28, 2007 | 08:42 PM
88JDO's Avatar
88JDO
I'd guess the master cylinder. You need to bench bleed the new one.
Old Sep 29, 2007 | 07:00 AM
Da Mail Man's Avatar
Da Mail Man
...here is a link worth reading......sounds like you m/c took a dump...but BEFORE you invest in a m/c, pull the wheels off and check for leaks at the brake calipers as well as at the m/c, especially at the rear of teh m/c where it attaches to the booster!
http://forums.corvetteforum.com/show....php?t=1769573
Old Sep 29, 2007 | 09:00 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
A small leak at one of the calipers can get all over the back of those big ole tires and never even make it to the ground where you can see it early on.
To Brake Problems
