buzz through bose with ign off
Old Sep 28, 2007 | 10:59 PM
jim davis's Avatar
jim davis
Cruising
Default buzz through bose with ign off
Recently bought '89 with 33,000 miles. After a dead battery when delivered, replaced battery. Now I have an inop Bose radio (cassette player does not work either), antenna does not go up when radio is turned on (no sound of motor running) in fact radio does nothing except clock and AM or FM station. With engine started there is a buzz that gets higher or lower depending on engine RPM. Buzz will continue after ignition is turned off and you have exited car, will cease when ctsy/clock fuse is pulled. Also have Service Engine Soon light on. Any thoughts?, bad ground ?, bad BOSE ?, HELP !!!!!!!!!
Old Sep 28, 2007 | 11:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
2 fuses power the bose system, radio and clock/courtesy, they both need to be good.
Do you know how to read the codes ??
Old Sep 28, 2007 | 11:41 PM
AGENT 86's Avatar
AGENT 86
Reading codes http://members.shaw.ca/corvette86/No...it%20Check.pdf
To buzz through bose with ign off
