94 ac will not turn off
Old Oct 7, 2007 | 01:30 PM
keepers15's Avatar
keepers15
Default 94 ac will not turn off
I am in need of help on my 1994 corvette,it has automatic ac control and will not turn off.I push the off button and nothing happens, I have removed the fuse thinking it would reset its self but that did not happen any advice ???
Old Oct 7, 2007 | 01:38 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
The control contacts may be dirty. Do a search, there's a good write-up on how to clean the contacts.
Old Oct 7, 2007 | 07:32 PM
Dads90's Avatar
Dads90
When mine sticks on auto, I push the recirculate to change the mode. Or push any button to try and trick the system. Then after a few minutes it will work right again.
Old Oct 7, 2007 | 07:56 PM
ynk1121's Avatar
ynk1121
common problem. take it apart and use alcohol and/or a pencil eraser to clean all the contacts.
Old Oct 7, 2007 | 08:02 PM
SunCr's Avatar
SunCr
Could be the contacts, but before you tear it apart, check the Blower Module Fuse - 5 amps - usually labled MDL in the fuse box. Your Processor (the Programmer), monitors the actual voltage delivered to the Blower Motor. If that circuit opens, the Blower can continue to run even with the ignition off. If the fuse is blown and it continues to blow with a replacement, the circuit is shorted to ground or the Blower Module is shot.
Old Oct 7, 2007 | 08:40 PM
quantum-theory's Avatar
quantum-theory
Are you sure that it is the AC and not just the blower? I had that problem with my 87. The blower would stay on even when I turned the engine off. I had to disconnect the battery to stop it or it would kill the battery. I had to replace a relay to fix it.I'm trying to remembor all the specifics, but I remember that the dealer wanted $534 for the relay. GM parts direct wanted $278. Discount auto parts charged me around $118 for the same bosch relay. You cannot get the Bosch part from Bosch. I received the Bosch part in a GM package from Discount.
Old Oct 7, 2007 | 08:50 PM
keepers15's Avatar
keepers15
Thanks to all,will try all replies
Old Oct 7, 2007 | 11:20 PM
SunCr's Avatar
SunCr
Just know that there isn't a Blower Relay with Electronic Air. Circuitry is contained in a Module mounted on the Evaporator Case (actually it sits inside of it enveloped in big heat sink). It gets low voltage signals from the Processor (Programmer for your Year) and that voltage is then amplified to control blower speed. You just might, to rule out some sort of memory glitch, disconnect and reconnect the battery first. Doesn't do much on the earlier Years, but the system became a little more sophisticated starting with the '90 and that sometimes helps.
Old Oct 7, 2007 | 11:29 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
I don't know why this works.....but it does.
To 94 ac will not turn off
