Heater Help
Old Oct 14, 2007 | 03:09 AM
Cessnapilot89's Avatar
Cessnapilot89
Default Heater Help
Hey Everyone,
My heater seems to not be working right. The other day I needed it for the first time since purchasing it in spring, but to my dismay no heat was coming out. The motor is blowing, and I dont have any antifreeze smell or sense of moisture on the passenger side. Checking the hoses going into the fire wall, they are both hot, but still no heat. The electronic climate control module is flipping out on me, could this be the reason for the lack of heat? Any and all help is greatly appreciated.
Old Oct 14, 2007 | 09:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like the temp door is not opening. There has been a few good threads lately, on this problem. A quick search should keep you reading for a while. Here's some info from my 86, just ignore the vacuum controlled water valve, I don't think the 89 has it.
http://members.shaw.ca/dankai/AC%20Electronic.pdf
Old Oct 14, 2007 | 01:05 PM
Cessnapilot89
THanks 86 for the link. In order to fix it, do I need to buy a new temperature door, or do I need to replace the electronic climate control module?
Old Oct 14, 2007 | 01:26 PM
AGENT 86's Avatar
AGENT 86
Your going to have to diagnose the problem. Could be the clip on rod, motor, controller etc.
Lots of info in this thread. http://forums.corvetteforum.com/show...highlight=heat
Old Oct 14, 2007 | 05:40 PM
badabing9's Avatar
badabing9
Old Oct 14, 2007 | 07:22 PM
Cessnapilot89
Thanks everyone for the help. Next weekend I will start taking stuff apart to see whats the matter. Hopefully that rubber seal is just hanging up the heater temperature door.
Old Oct 14, 2007 | 08:59 PM
Cessnapilot89
How do I get to the temperature door from the hush panel? I just took it off and all I can see is an endless mass of wires.
Old Oct 14, 2007 | 09:57 PM
dudman's Avatar
dudman
Don't just assume it's the temp door. On my 93 I was able to remove a small cover on the firewall side and watch it open. I too thought that if both heat hoses were hot the core was not plugged. That turned out to be an incorrect assumption. I was able to flush the heater core with a water hose attached to one of the hoses going through the firewall and had the other hose spilling into a bucket. Lots of junk came out and the heater was salvaged. This may or may not be your problem. As stated before, there are lots of threads on this. Good luck.
To Heater Help
