woot the vette is BACK!
Last time I had it in the shop a cracked break booster that was replaced fixed a lot of the problems but not everything. This time my mechanic kept it over a month but when it came back it runs like a DREAM! Replaced the O2 sensor, checked all the wiring and vacuum lines and completely cleaned all the debris off the radiator shroud and this made a HUGE difference! It used to run so hot I couldnt drive it at all if it was over 80 degrees but now I can run the AC and the temp never gets over 190 degrees even idling in traffic
