1988 Corvette - won't start
Old Oct 22, 2007 | 06:19 PM
KimberD's Avatar
KimberD
1st Gear
Default 1988 Corvette - won't start
I've got an 88 Corvette that won't start ... ECM code 46 ... been to too many auto shops to count ... does anyone have any advice for me? How do I fix my car?
Thnx
Dave
Old Oct 22, 2007 | 07:32 PM
redwing76's Avatar
redwing76
Thnx
Dave
code 46 vats, http://www.corvettebuyers.com/c4vettes/ecm.html
www.corvettecentral.com anti theft by pass switch yr 1986 1989
The anti theft lock-out is locking you out.
Do you know your key code?
Try your spare key, no spare try a lock shop for a new key. Or disable the piece of shizt vats.
Old Oct 22, 2007 | 07:43 PM
All2kool's Avatar
All2kool
And this is how I did disable VATS on my 1989 Trans Am:
The VATS is controlled by the ECM. Changing locks (PITA) will only work if the key stays the same VATS number, of which there are 15 possibilities. Disabling your VATS would be a solution. Go to a locksmith, they will test your key and be able to sell you a module to disable VATS. Remove the underdash panel on the driver side. You should easily spot a two-wire grouping, I believe yellow/orange/green and white, just to the right of the steering column (as it was on my 1989 TA). You should notice that it disconnects in the middle. Disconnect it, insert the module you got from the locksmith into the wire going towards the firewall. Voila, VATS is now disabled. The module will cost you $25 - and your car will never not start because of VATS. It actually took me longer to remove the underdash panel than it did to locate the wire and insert the module.
As for the security feature of VATS being disabled, only you will know. A car thief will likely pass your car by for another, like a Camry or Honda.
To 1988 Corvette - won't start
