codes
Old Oct 25, 2007 | 02:34 PM
ARMAN72's Avatar
ARMAN72
Default codes
where is the plug on a 93 to run the codes. i looked under and cant seem to find it
Old Oct 25, 2007 | 02:58 PM
jrp's Avatar
jrp
It should be just above your right knee as you sit in the driver's seat, right at the edge of the dash panel.
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Oct 25, 2007 | 03:00 PM
ARMAN72's Avatar
ARMAN72
I m guessing you remove the cover under the steering wheel?
Old Oct 25, 2007 | 03:08 PM
jrp's Avatar
jrp
Not on my '96, and I've never seen it mentioned for other years. If you get your head down far enough to see the edge of the dash and still don't find it, I would assume it came loose & got stowed or was moved by a previous owner.
Old Oct 25, 2007 | 03:22 PM
ARMAN72's Avatar
ARMAN72
i found it thanks!
To codes
