Wheel Hub Replacement
Old Oct 27, 2007 | 07:41 PM
Chapindad's Avatar
Chapindad
Default Wheel Hub Replacement
I have pulled the wheel hub. My question is on lubrication. The parts store said to pack it with grease but I think that is full of something brown. But the instructions for the new wheel hub said to use grease but it was not clear on the amount or type.
Old Oct 27, 2007 | 07:47 PM
Sam Lam's Avatar
Sam Lam
That brown stuff is old wheel bearing grease! Go to a auto part store and get a name brand wheel bearing grease like Valvoline. Avoid buying the Wal Mart, etc type grease. You should thoroughly clean all the old grease out of the bearings and repack them with grease. There is a technique to packing the grease into the bearings. Send me a PM if you want more info on this.
Bob
Old Oct 27, 2007 | 08:47 PM
Chapindad's Avatar
Chapindad
My wheel hub is a self sealed kind which is why I am confused on the grease. I wish I could have just done the bearings like in my old 71 firebird. Sp instead of $20 a wheel, it was $170 a wheel.
Old Oct 27, 2007 | 10:08 PM
Mojave's Avatar
Mojave
C4 wheel bearings are sealed. You can't grease them. It is impossible to take them apart without destroying the bearing races (which are plastic). If you have a wheel bearing problem, you just have the replace the entire hub.
Money saving tip: 4th gen Camaros/Firebird (93-02) use the same front wheel bearings, EXCEPT the bolt holes are threaded. Usually the f-body hubs are cheaper, and you can just drill out the threads. The f-body hubs also all have ABS, and even if you have an early car with no ABS, they work just fine.
Old Oct 27, 2007 | 10:17 PM
Chapindad's Avatar
Chapindad
Do you put anything on the gear?
Old Oct 28, 2007 | 12:02 AM
Sam Lam's Avatar
Sam Lam
Have you even made a posting, read it later......and asked yourself......what is hell were you thinking when you wrote that
Sorry to cause a problem with my posting :o
96GS#007's Avatar
96GS#007
No, you don't.
Old Oct 28, 2007 | 10:19 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Did one myself about a month ago.
Old Oct 28, 2007 | 10:32 AM
EvanD's Avatar
EvanD
CF Community Team
The "gear" is not a gear, it's the part the wheel speed sensor senses. No grease...
Old Oct 28, 2007 | 07:14 PM
Chapindad's Avatar
Chapindad
Ahhh... Thanks for the info. I replaced both the front hubs, but I still have some rear sway so I will replace the rear tomorrow. Expensive but still a lot less than a car payment and I love my car...
Old Oct 29, 2007 | 03:28 PM
Bob89c4's Avatar
Bob89c4
Just did the rears on my 89 two weeks ago.....I was starting to sweat bullets reading the first couple posts here. The only grease I saw was in the right rear hub that fell apart as I was taking it off!
To Wheel Hub Replacement
