Battery Issue
Old Nov 3, 2007 | 06:47 PM
deerra's Avatar
deerra
Default Battery Issue
My 92 sat for a week (been sick).
Tried to start - battery completely dead. No previous battery problems. Put it on my charger and the charger doesn't register. Great I think, now the charger is dead. Put the charger back on the boat battery and charger works. WTF!! I put my 2 amp Battery Tender on the Vette and same thing. No lights. Not charging. Put the Battery Tender on my bike and it lights up.
So it seems the battery won't take a charge. Is that possible?
Or, could the battery be okay and I have some other issue?
Prior to this the car started and ran fine.
Any help or suggestions would be appreicated.
Old Nov 3, 2007 | 07:31 PM
78pacer's Avatar
78pacer
It appears the battery plates have shorted out and fried. A common occurance. Time for a new one.
Mike
Old Nov 3, 2007 | 07:47 PM
deerra's Avatar
deerra
Thanks for the help.
I dread R&R'ing the battery as much as shelling out for a new one.
Old Nov 3, 2007 | 07:52 PM
Goldcylon's Avatar
Goldcylon
You have a dead cell which has shorted out a plate inside. So whenever you put a load on it fails. Solution take to you local parts store get it tested and leave it as the core. I predict a new battery is in you near future. Oh an a long corvette lifeline. GC
Old Nov 3, 2007 | 07:58 PM
Nzzz's Avatar
Nzzz
Pardon my ignorance but why does the battery do that? You can't let it sit for a week without it going dead?
Old Nov 3, 2007 | 07:59 PM
78pacer's Avatar
78pacer
Replacing the battery is not a tough job, 2 beers max....
Mike
Old Nov 3, 2007 | 08:03 PM
deerra's Avatar
deerra
Which is easier - take it out via the side or remove the stuff on top?
Old Nov 3, 2007 | 08:05 PM
Goldcylon's Avatar
Goldcylon
Side... No question
Old Nov 3, 2007 | 08:06 PM
deerra's Avatar
deerra
Thanks. I'll get to work.
Old Nov 3, 2007 | 08:09 PM
Goldcylon's Avatar
Goldcylon
The plates corrode as sulfate and other impurities builds up on the internal plates. This is also an accelerated process due to the factors of Heat, Age and sadly the water (electrolyte) levels getting to low on the top of the plates.
Also a bad voltage regulator can over charge the battery and the alternator can continually overcharge it until the plates boil. GC
Old Nov 3, 2007 | 08:10 PM
Goldcylon's Avatar
Goldcylon
No prob. Been there and done this many times before. GC
Old Nov 3, 2007 | 08:11 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
It was already on it's way out, the 2week's just helped it along.
Old Nov 3, 2007 | 10:59 PM
jfb's Avatar
jfb
Those who advised that the battery had an internal short, this would cause a battery charger to trip its circuit breaker!!!!! Your dead battery had fully sulphated plates. Lead sulphate is an insulator and makes your battery look like an open circuit. A battery not near its end of life time, should not discharge totally in 7 days with normal car leakage current. When you connect the new battery, connect the positive terminal first and then connect a test meter that can measure amps from the negative battery cable to the battery negative terminal and set the ammeter on its highest range and wait for the courtesy light to time out and then switch the ammeter to lower scales to measure the leakage current. It should not be higher than 50 milliamps. My 87 draws 27 milliamps. I suspect that you have high leakage current which discharged your battery and in 7 days it ruined the battery.
Old Nov 4, 2007 | 01:33 PM
deerra's Avatar
deerra
Thanks for the information. I'm not too sure about how to hook up the test meter. If I attach both battery cables then I would assume I'd get a normal reading on a new battery. Could you clarify that for me.
Thanks.
Old Nov 4, 2007 | 01:45 PM
jfb's Avatar
jfb
When you install the new battery, only connect the positive cable to the positive battery terminal. Then set you multimeter to measure amps, usually you have to unplug the positive test lead into a socket on the meter marked, "amps". Then connect the negative test lead to the negative battery terminal and connect the positive test lead to the negative cable. An ammeter is always connected in series with the circuit you are measuring the current in. When you make connection, the courtesy lights will come on and you will have to wait for them to time out, or if you don't want to wait, then unplug the courtesy light fuse. Read the current on the meter, GM says leakage current must not be over 50 milliamps, that is .05 amps.
If you have excessive leakage current, then you will need to find out what is drawing current so that you don't ruin another battery. Don't connect the new battery until you determine that leakage current isn't excessive.
Old Nov 4, 2007 | 02:13 PM
georgesauto's Avatar
georgesauto
My 84 has a battery problem also
it will only hold a charge for about
1 day
The current measurements:
trabsient 599 ma lowering
to 130 mA (WHY?).
Ignition on 6 Amps.
I suspect the radio??
Old Nov 4, 2007 | 03:32 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Much faster from the side.
To Battery Issue
Old Nov 4, 2007 | 10:02 PM
jfb's Avatar
jfb
1 day
to 130 mA (WHY?).
Ignition on 6 Amps.
With your ammeter in place, start pulling fuses and watch the ammeter. This may find the offending circuit. There are other circuits that use a fusible link or a circuit breaker (I think all of the circuit breakers are fed from a wire that has a fusible link) and these need to be removed one at a time if no fuse removal shows where the leakage is.
Old Nov 4, 2007 | 10:31 PM
deerra's Avatar
deerra
Thanks for all the help.
Old Nov 5, 2007 | 12:24 AM
Goldcylon's Avatar
Goldcylon
No problem glad you got it back together.
