latch assembly
Old Nov 20, 2007 | 12:28 AM
lynchgj's Avatar
lynchgj
7th Gear
Default latch assembly
I'm new here, so bear with me.
I've been (trying to....) restoring an '85 coupe, and I'm trying to work on the rods and clips (what a job that was) on the passenger door outside handle and latch mechanism, some may call it a door latch assembly, or a door lock fork, well whatever it is, the fork section of the mechanism is closed and I cannot get it to open to close the door. This fork wraps around the door striker when the door closes. Anyone have any ideas??
Old Nov 20, 2007 | 08:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check your other thread
Old Nov 20, 2007 | 01:29 PM
nferr's Avatar
nferr
You can reach up in there above that latch with a screwdriver and push that latch open. I did it once when mine jammed.
To latch assembly
