c4 heater
Old Nov 26, 2007 | 02:17 PM
mbrownle's Avatar
mbrownle
4th Gear
Default c4 heater
I have a 92 c4 with auto temp control that blows cold air in the winter. Does it have a water control valve? If so, where is it?
Is it controlled by vacuum? From where?
Could it be a clogged heater core?
Thanks. I'm tired of being cold
Old Nov 26, 2007 | 03:27 PM
badabing9's Avatar
badabing9
the search function of the forum should yield some answers and direction for you until you get a service manual.
Old Nov 26, 2007 | 07:29 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
The FSM is a must. I am in the middle of replacing the temp control door on my 88. No water control valve in an electonic temp control. I am going to try scanning my FSM manual pages that will point you in the right direction, If I can get my scanner to work. I'll send you to if it works.
To c4 heater
