Starter Problem
Old Nov 30, 2007 | 12:47 AM
hman1987's Avatar
hman1987
Default Starter Problem
For the last day or two I have encounter problems starting the vehicle. It would ask like a dead battery only to start the next time you cycled the key switch. Cables were clean and the battery seemed fine...when it would crank, it cranked like there was no tomorrow.
Today, it sounded like the starter was "hung" and when I tried to turn the car off (key back) the start kept cranking the car over. I paniced and turned the key forward and the car started right up still making the noise for another minute or two then settled down and ran normally.
I looked up starters at the parts house but I am not sure if it is the starter or the solenoid. I did not see a solenoid online, only a solenoid relay. Are these one in the same?
Old Nov 30, 2007 | 01:52 AM
deerra's Avatar
deerra
My 92 did the same thing. The starter was shot - I replaced it.
You could pull it and have it checked at Auto Zone.
Old Nov 30, 2007 | 09:10 AM
hman1987's Avatar
hman1987
Thanks.....I guess I will do it tomorrow.
Old Nov 30, 2007 | 01:05 PM
QZRBLU's Avatar
QZRBLU
2017 C4 of Year Finalist
Sounds like all you need is to replace the solenoid. They sometimes hang up if they have some corrosion inside. Once it hangs, the starter gets 12V all the time until it releases.
You also have a starter enable relay but that is separate from the solenoid and NOT your problem.
Mick
To Starter Problem
