Lo
Old Dec 16, 2007 | 12:28 AM
slicked25's Avatar
slicked25
Default Lo
According to the OM;
If the oil and coolant temperatures are below 32 degrees, the trip monitor will display LO when the actual gage temperature is displayed.
So yes it's below 32 here and I saw the LO in the display and I tried to crank the car and she wouldn't turn over. The lights worked and checked all possibilities that I know of and it looked good so I figured I'd try to give her a boost. Hooked up the booster cables to the other car and before raising the hood on the Vette I tried one more time and what do you know she cranked. I recently installed a new battery and alternator but I swear this car has a mind of it's on. I can't find much info on LO. Could this be related since this has happened before last year when it was ice cold outside?
Old Dec 16, 2007 | 12:35 AM
RRT vette's Avatar
RRT vette
The outside temp could be related to the no start but not the LO on the gauges.
Is this what you are asking?
Old Dec 16, 2007 | 12:43 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The "LO" on the readout simply means that the oil temp is below freezing. It will not prevent the engine from starting. The fact that it won't turn over means a problem somewhere within the cranking system. The possibilities are endless here but shouldn't be hard to pin down with a methodical approach.
Old Dec 16, 2007 | 05:40 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
That's crazy talk.
Some of the best GM dealerships use the "replace parts until it works" methodology.
Old Dec 16, 2007 | 05:57 PM
Aardwolf's Avatar
Aardwolf
The oil temp gauge on my '88 reads LO till 150° which takes running a few mins to get that high. The coolant reads LO till 100° IIRC. From what I remember a gauge is made to read a narrow range of data so that it is more accurate.
My aftermarket trans temp gauge reads LO till 70° and on days that it is warmer then that. is a good gauge for outside air temp.
Old Dec 16, 2007 | 06:17 PM
86 Red Neck's Avatar
86 Red Neck
could it be the VATS system ?????
Old Dec 17, 2007 | 07:07 AM
Billy Stargazer's Avatar
Billy Stargazer
That would be my guess.
Old Dec 17, 2007 | 07:24 AM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
That's what I was thinking too. Will the car start up 10 minutes after having the initial problem? If so, could be the vats. Try a different key. The pellet on your key might be worn out. That's what I went through. Then I purchased a new key, and never had the problem again....
Rik
To Lo
