Tranny Help!!
Old Dec 17, 2007 | 07:50 PM
1/4 Mile's Avatar
1/4 Mile
Default Tranny Help!!
Probably a stupid question, I'm pulling a 4 3 tranny and an automatic. How do you get the shifter ***** off, or do you have to take the shifter itself off??
Any help is greatly appreciated.
Old Dec 17, 2007 | 09:08 PM
staugur's Avatar
staugur
If you filled out your profile it would help.What years etc.??
On the auto, needle nose pliers and pull out the shift button and you will see a circlip down in there that needs to be removed.Then the **** will lift off. Don't know anything about stick shift.Probably just brute force in an anticlockwise direction.
Old Dec 17, 2007 | 09:31 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
On the sticks under the patern indicator is a wedge that you have to pull up and out, then unscrcrew the ****. It can sometime be a real ah, bear, to get out.
Old Dec 17, 2007 | 10:20 PM
1/4 Mile's Avatar
1/4 Mile
Thanks for the help. I'll see if I can't figure out how to fill out my profile.
To Tranny Help!!
