Instrument Cluster Replacement
Old Dec 19, 2007 | 08:18 AM
Gl!tch's Avatar
Gl!tch
Default Instrument Cluster Replacement
Is there a somewhat simple way to remove and replace the Instrument Cluster component in a 93 Coupe?? I finally removed mine yesterday but it came out with extreme prejudice. I removed the bezel and then the cluster lens to be able to rotate it around somewhat but getting it around the steering wheel and column met with a high degree of difficulty. I am going to replace it this afternoon but was checking to see if there were any K.I.S.S. options that I was missing.
Thanks for any help!
Floyd
Old Dec 19, 2007 | 08:39 AM
Goldcylon's Avatar
Goldcylon
Floyd
Floyd did you drop the steering wheel? If you didnt im surprised you didnt break the trim and such. Losen the tilt lever. Remove the drivers side hush panel. 2 screws on the left panel and 5 underneath where your feet go. I suggest removing the screw that holds the ALDL connector and unplugging the hush panel light so you can move the entire hush panel out of the way. Then remove the metal support plate that the hush panel screws into and then remove the tilt lever (you leave it in until the last minute as you may have to jocky the steering wheel up an down while your working on it) Now drop the two nuts holding the steering wheel. The job will be so much easier.
Also Floyd if I may suggest buy a used Factory Service Manual (FM) for your 93. The pictures and step by step procedures are invaluable. Buy the big red Helms book only, the white ones are not complete.
Old Dec 19, 2007 | 09:26 AM
Gl!tch's Avatar
Gl!tch
Daryll -- Thanks. Guess I was trying to do it in what I thought was going to be the easy way. I do have the correct service manuals that I just bought from another member but my dumb butt didn't think I'd need it for this one. I wasn't too sure about doing anything with the steering column, kinda like the first time you open up a computer to replace a part. Thanks again, Floyd
Old Dec 19, 2007 | 01:34 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
I just got my instrument cluster cetification too. I dropped the wheel several times before I finally sent the cluster off for a rebuild. It's back in now and working fine.
Old Dec 19, 2007 | 01:39 PM
Goldcylon's Avatar
Goldcylon
LOL im a certified member in this club (now) . Last time I replaced the instrument cluster lens the entire job was done in 30 Mins. The old lens was gouged and scratched by the previous owner
Old Dec 19, 2007 | 01:42 PM
Goldcylon's Avatar
Goldcylon
Understood after you get in there a few times its really pretty easy just a PITA and back for that matter to work upside down. Easier with the seat out but not really nessary to go to that extreme. Good luck. D
Old Dec 19, 2007 | 05:34 PM
Gl!tch's Avatar
Gl!tch
BTW ...Had screen name changed to Gl!tch. Kinda worked for me considering I am a network/computer tech.
Also...waiting for the next season of Battlestar! I'm a fan from the original and even though it took a while, got into the new one.
Old Dec 20, 2007 | 10:26 AM
Tommy T-Bone
I like to keep the seat in. That way I can hold up the steering wheel with the left arm and reach under with my right to balance the support bracket and start the bolts. The fewer items you have to remove, the better.
Old Dec 21, 2007 | 09:17 AM
Bubba91's Avatar
Bubba91
Floyd
I had to replace mine too. I put in white guages while I was in there.
Old Dec 21, 2007 | 07:53 PM
Goldcylon's Avatar
Goldcylon
TTB you must be a real smealt guy. Im 6'2" and 240 and its a little tight. But the less to remove and get the job done always works for me.
Old Dec 21, 2007 | 11:27 PM
Dads90's Avatar
Dads90
Hey Tommy, how long was it away on the rebuild? and how much did it cost ? I'm sure mine needs service.
Old Dec 22, 2007 | 08:52 AM
Tommy T-Bone
Turn around was about two weeks. Cost me $325 plus shipping up there. No return charge for shipping. The whacky tach was repaired and all of the bulbs and sockets since the bulbs I bought online did not fit the sockets in the dash. The lcd screen was not reading in the daytime and barely at night because one of the bulbs was fried. They test the entire system to insure accuracy of all guages. Plus they gave me a new lens cover since I shipped the unit only minus the cover.
Old Nov 14, 2022 | 08:43 AM
carnutbill's Avatar
carnutbill
Navigator
this is how I did mine
C2 GAUGE CLUSTER REMOVAL 1967 no air, standard transmission
start at bottom of gauge cluster & work up removing items
FYI harness is held into the top of cluster with 2 plastic clips
OPTIONAL Remove seat, put pillow for you head near pedals,
put feet in back where the seat was
1 disconnect battery
2 unscrew hood release under gauge cluster
3 unscrew headlight door switch under gauge cluster
4 remove 3 bolts holding column bracket under dash
remove 2 screws holding column bezel under gauge cluster
5 under hood loosen 2 clamps on column & loosen rag joint at end of column
6 unplug column wire connector & remove column
7 remove 5 perimeter screws in front of gauge cluster
install 2 or 3- 8" 1/4-20 rods in perimeter holes,
& pull gauge cluster out 2", tilt bottom of cluster out.
8 remove trip odometer cable from back of cluster
OPTIONAL under hood loosen oil line & tachometer cable for slack under dash
9 disconnect oil line, speedometer & tachometer cables on cluster
10 put ignition switch on accessories & put paper clip in hole next to
key, push paper clip in while turning key to left, tumbler will come
out & then unscrew bezel, leave wires on switch
11 push pin under headlight light switch & pull-out headlight rod &
unscrew bezel leave wires connected to switch
12 disconnect wiper wires & lighter wires from behind cluster,
Identify wires with masking tape if you want
13 disconnect fuel & battery connectors & label if you want
14 unplug parking brake light, hi-beam light, directional, ground wire, cluster lights etc.
15 harness is held into the top of cluster with 2 plastic clips, squeeze with
needle nose pliers & wiggle out.
16 remove ground wire on top
Old Nov 14, 2022 | 10:25 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Hey Bill - there is a "related topics" or "related threads" feature (which you can disable) which often directs you to a thread you didn't really intend to post in. You have posted about your C-2 '67 in the C-4 section (1984-1996) and this thread is from 2007! You might want to put it in C1-2. I'll see you there, I have one of each!
To Instrument Cluster Replacement
