Intermitent starting problems
Old Dec 23, 2007 | 02:54 PM
C4L98's Avatar
C4L98
5th Gear
Default Intermitent starting problems
Hi all, I want to ask for your help with a problem that is driving me crazy. I have a '91 vette. The problem is with starting the car. Without any reason some times it just don't start. I turn the key and hear a click in the engine (I suppose is a starter switch) but nothing else. It just don't crank or do anything (the VATS light turns off in the dash also, by the way). But suddenly, after a while and some tries, it start like nothing have happened. When the failing start is happening, I can start it by connecting the starter motor directly to the battery and starts in the first try.
Does anyone have any idea what could make this happening?
Thanks in advance for your comments and help.
Old Dec 23, 2007 | 03:14 PM
wazup's Avatar
wazup
Default starter
It does sound like your starter. I had similar problems with an older ford (years ago) and my wife's toyota this past week. Like you indicated, her car did start after a few attempt. No problems for about a week then it would not start at all.
Old Dec 23, 2007 | 04:13 PM
RRT vette's Avatar
RRT vette
Check the connections at the starter solenoid. The contatct become pitted and will cause the problem you're describing.
Old Dec 24, 2007 | 01:11 AM
jfb's Avatar
jfb
First, remove your battery cables (neg cable first) and clean the cable lugs, bolts, and battery posts and replace the cables (neg last). Starter motors draw 100+ amps and they require a clean tight low resistance cable connection to the battery. Battery posts slowly corrode and need to be periodically cleaned.
If you can keep hitting the crank position and the starter finally cranks and the battery posts are clean and tight, then you have worn pitted contacts inside the starter which can be replaced. At the end of the starter solenoid stroke, the solenoid forces two large copper contacts together that switch current to the starter motor and after a lot of use, these contacts become black and pitted and don't make good connection. An auto electrical shop can replace the contacts or you can do it yourself.
Old Dec 24, 2007 | 01:49 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Def. check all your connections...they can be very finicky.
Old Dec 24, 2007 | 01:15 PM
myblue91's Avatar
myblue91
C4L98- had the same experience with my 91. Finally cleaned all the connections on the starter,and no problems since. with jfb. Good luck, Doug
Old Dec 28, 2007 | 09:26 AM
89 Bob L's Avatar
89 Bob L
Clean the battery and starter connections.
To Intermitent starting problems
