C4 Frame Spec
Thnaks
B bolt hole used for skid bracket attachment. In bottom of rail remove splash guards for access.This is near the front part of the chassis
F welded nut in hole bottom of rear rail pocket near rail drain hole.This is at the rear of the chassis
G slot and hole in bottom of rear cross member
straight line front to rear B to G 2151mm
straight line side to side F to F 991 mm
There are more marker points and data but these should show if there is a problem
I just remove the rear impact bar and find out that the frame is a bit bent. Nothing serious I think, I will take a lot of pictures and try to find a place to make it straight. The car goes like a charm a bit of investment won't be too bad.
Thanks again
Thanks a lot that will help me and also the body shop were I should bring the car. The car was hit in the right quarter panel and the end of the frame is about half an inch in, the drivetrain seems ok but I will find out soon.
Thanks again
