interior lights help
Old Jan 9, 2008 | 02:26 PM
keepers15's Avatar
keepers15
Default interior lights help
I am having problems with my interior lights,back lighting for my hvac controls and the red accent lights in the doors do not light up along with the mirror accent light .Courtesy lights in the door light normal,when courtesy lights are turned on at the light switch they work normal.I checked all the fuses and they are ok,also the back lighting on my headlight switch do not work.Where do I go next???
Old Jan 9, 2008 | 08:51 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Doesn't make any sense, does it? You definitely have a grounding problem. Your FSM Electrical Manual explains that most switches, switch to ground. Just the opposite than your house.
Old Jan 10, 2008 | 07:51 PM
EvanD's Avatar
EvanD
CF Community Team
Silly question have you checked the bulbs? I thought the doors and mirror orange light and white light was the same bulb but I found out mine were just blown....
Old Jan 11, 2008 | 12:23 PM
keepers15's Avatar
keepers15
all the bulbs are good,I am not getting any power to these lights.What I need to know is where the power comes from to the red accent lights?
Old Jan 11, 2008 | 03:37 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
On our 94 coupe, when the headlight/parking light switch is turned to the parking light position, the door and mirror soft orange lights come on. Interestingly, when the door is opened, those lights go out.
So, looking quickly at the FSM schematics, I would suggest checking your door switches and the ambient light sensor.
To test the door switches, with door closed, simply turn key on, turn on radio, turn off key, and then open door, does the radio go off?
To test the ambient light switch, refer to FSM page 8A-114-10 (i.e. put ccm into diagnostic mode and review parmater 3's readings).
Old Jan 11, 2008 | 08:17 PM
hustled4's Avatar
hustled4
4th Gear
your dimmer switch is bad. it is ac delco part #d1509b. to the left of steering collum under dash. looks like a silver heat sink. also call incandesent power driver
Old Jan 12, 2008 | 03:58 AM
keepers15's Avatar
keepers15
I checked more today and ran a jumper wire to the red lights on the headlight switch and they came on(gray/black&purple/white on the fog light part of the switch),I could not find any power running to these wires, I will use multimeter today and find why the power is not getting to them.I will post what I find!
Old Jan 15, 2008 | 02:30 PM
keepers15's Avatar
keepers15
[QUOTE=keepers15;1563587230]I checked more today and ran a jumper wire to the red lights on the headlight switch and they came on(gray/black&purple/white on the fog light part of the switch),I could not find any power running to these wires, I will use multimeter today and find why the power is not getting to them.I will post what I find! Ambient power driver replaced,red accent lights repaired.Thank you Theadmiral94,hustled4 (ambient power driver) part#d1509b
Old Jun 10, 2008 | 11:15 PM
EGT1's Avatar
EGT1
I have a 1992 LT1 with an interior light problem also! The lights work fine when turned on by the dimmer switch, but they do not come on when the doors are opened. Is my problem with delco part #d1509b also?
To interior lights help
