Build sheet
Old Jan 20, 2008 | 01:13 PM
tonypny's Avatar
tonypny
Default Build sheet
I just recently purchased a 93 Anniversary and was wondering where the build sheet is located.
Old Jan 20, 2008 | 01:24 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
its on the gas tank. but your best bet is to order a new one from the National Corvette Museum
https://store.corvettemuseum.com/ser...buildsheet.asp
Old Jan 20, 2008 | 02:03 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Old Jan 20, 2008 | 02:27 PM
trulytex's Avatar
trulytex
And I also hear that some people have found one inside the frame in the engine compartment.
Old Jan 20, 2008 | 02:38 PM
tonymax2's Avatar
tonymax2
What do you want one for?
Old Jan 20, 2008 | 07:24 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
In the frame rail -- broad cast sheet
Old Jan 20, 2008 | 07:58 PM
MARKRUBYRED's Avatar
MARKRUBYRED
It is stuffed in the frame rail just under the power steering reservoir. It is a pain in the butt to get out but worth it.
Mark
Old Jan 20, 2008 | 08:04 PM
MRHTRD's Avatar
MRHTRD
Just received 40th Ruby build sheet from the NCM. If you purchase from them, make sure that you have send it laminated. I also purchased the window sticker. Each time that I have sold one of my corvettes, it has been a big plus to have this information to pass on to the new owner.
Whatever you pay for them will be returned in spades !!!
Old Jan 20, 2008 | 09:05 PM
blkzr1's Avatar
blkzr1
Default build sheet
hi, i was able to recover mine from my 1995 from on top of the gas tank by loosening the right tank strap and reaching through the tag space after removing the tag. it was in good shape but not perfect. see ya
Old Jan 20, 2008 | 10:30 PM
tonypny's Avatar
tonypny
It's a low mileage (16,500mi) car and I plan on showing it and it's nice to have along with the window sticker that came with car.
Old Jan 21, 2008 | 05:10 PM
MARKRUBYRED
It is nice to have the original build sheet and getting it from the frame rail is the only way to go. It took me five hours using a needle nose plyers and some dental tools but it was worth it. The one from the museum is a photo copy and not the real thing if originality is your goal and I would not try to retrieve it from the tank since you have to loosen the straps There might be a thread on the 40th registry site on how to remove it from the rail under the power steering reservoir since that is how I got mine.
Good luck,
Mark
Old Jan 27, 2008 | 09:43 PM
tonypny's Avatar
tonypny
Good luck,
Mark
I found the build sheet in the frame as you mentioned. It took about 2 hours and hard to get it out in one piece, got it out in five pieces and able to tape together. Looks pretty good. Just wondering if you were able to get yours in one piece. Thanks for the info.
Old Jan 28, 2008 | 08:46 AM
MARKRUBYRED
I got the main sheet out with two or three small portions that I pieced together. After that I had whole thing laminated @ Kinkos and keep it on display in my car room. During shows I use the copy that you can get @ the museum since the sun can really due damage to the original. I remember the feeling of accomplishment getting the original out from the frame rail although the wife thought I was Further, I still have the build sheet intact sitting on the tank. Great job and post some pic's. You should feel proud of retrieving the original birth certificate of your Ruby after sitting in the frame for over 15 years.
Mark
Old Jan 28, 2008 | 11:57 AM
timmy 93's Avatar
timmy 93
Mine was in the same place.But not in good shape. ( 1993 )
Old Jan 28, 2008 | 09:23 PM
No Wife's Avatar
No Wife
It may be a broadcast sheet however, what I pulled out of the frame is identical to the “build sheet “ the museum sold me.
The difference is it is not a copy. It actually came out of the car. After it was dried out and ironed flat it looks great.
Old Jan 28, 2008 | 09:30 PM
tonypny's Avatar
tonypny
Mark
I'm trying to post some pics and can't seem to figure it out. Any idea
Old Jan 28, 2008 | 10:36 PM
edge56's Avatar
edge56
Cruising
Default Built sheet
Do all of the Vettes have two built sheets? One on the tank an the other in the frame. I have a 95
Old Jan 30, 2008 | 07:15 PM
ps374's Avatar
ps374
I just got mine in the mail yesterday. I was told that what the Corvette museum is sending us is NOT a copy but a hand typed blank look a like invoice. Same with the build sheet.I also noticed options differ in price from the Corvette black book. Z51 option is listed at $600.00 in the Corvette black book but the invoice says $51.00. This little bundle cost me $80.00. Anyone have opinions?
To Build sheet
