Torquing bolts
Old Feb 4, 2008 | 05:18 PM
JonnyAngle's Avatar
JonnyAngle
Default Torquing bolts
After putting the plenum back on, do I need to make sure the torx bits are at a specific torque on the runners?
Old Feb 4, 2008 | 05:37 PM
Pete K's Avatar
Pete K
Every bolt has a correct torque, so the technical answer is yes. However, you are only sealing air, so snug and even are usually good enough.
Old Feb 4, 2008 | 05:46 PM
Square's Avatar
Square
I believe I set mine at 25ft/lbs since both pieces are aluminum.
Old Feb 5, 2008 | 07:48 AM
bd2626's Avatar
bd2626
Just did mine over the weekend, I think its 18 for the Throttle Body.
Old Feb 5, 2008 | 08:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
Either way is fine, but on stuff with old threads Im with Pete. Get them to snug, or just a touch past depending on how strong the thread feels and leave it.
Old Feb 5, 2008 | 08:51 AM
Muffin's Avatar
Muffin
The 85 specs out at 17. I settle for 20 with a dab of anti-sieze.
To Torquing bolts
