84-89 Instrument Panel Bulbs?
I took my bulb assembly to Napa and for a few bucks I got new bulbs and plastic bulb holders.
'89 uses those blade type halogens, '84-'88 use the bi pin style. Sounds like they sent you the wrong ones.
This is an 882
http://www.servicelighting.com/catal...m?prod=MB42100
This is an 882
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
FWIW, The 882's are very bright AND develop a lot of heat in the process.
After repairing my cluster, I converted the lites to the 194's.
These are not as bright, but very legible in day light.
Cheaper to replace, and easier to find.
?? part number ?? supplier ??
Here are the facts:
From 84 to 88 Delphi installed a halogen lamp assembly, in 89 they used a Stanley Xenon lamp because the light tubes were melting in the clusters. All clusters from 89 forward, when serviced, should switch to the Xenon lamp & socket. FWIW 194's will short out the power supply, as they draw too much power, The newspaper is also a BAD idea.
Here are the facts:
so much info in this thread, what to choose?
So, Ken- what would you suggest for replacement in '84-'88 clusters?
