Headers!
Old Feb 15, 2008 | 01:32 PM
pearlvett's Avatar
pearlvett
Default Headers!
So what would be the best headers for my 85? I want some that i wouldnt have to do modifications and i dont really care about smog stuff (as long as it doesnt mess with the computer), and i would really like long tubes unless yall dont think it will benefit to much.
Old Feb 15, 2008 | 01:48 PM
85 500 horse's Avatar
85 500 horse
I had a set of TPIS headers installed in my 85 and I was told by my installer that they went in w/o a hitch. Many times, modifications need to be done to get headers to fit just right. But apparently, TPIS was able to make these fit into an 85 perfectly. The only downfall is their cost. It is very steep. But, if it's not a problem and you want an excellent header, you probably can't beat this one.
Old Feb 15, 2008 | 01:54 PM
mdlfcrss's Avatar
mdlfcrss
If you use the search function, you'll find enough material on headers to choke a horse. Posting that question here just allows us to post goofy little pictures like this...
by the way, I put a set of Hedman's in my '91 in the garage. No major problems, I just had to make my own alternator bracket and find a new home for the oxygen sensor. Good luck... Oh, one more thing, due to heat problems, make sure the headers you end up with are thermal coated!
Old Feb 15, 2008 | 02:09 PM
pearlvett's Avatar
pearlvett
Ok so about how much are those running for?
Old Feb 15, 2008 | 02:18 PM
85 500 horse
About $750 + the Y pipe for an additional $125. I suggest you get them coated.
http://www.tpis.com/index.php?module...aust%2FHeaders
(On the above link, hit "next" twice).
Old Feb 15, 2008 | 04:53 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
EM
Old Feb 16, 2008 | 08:13 AM
pearlvett's Avatar
pearlvett
Ok soanother question if i delete the smog pump and get rid of the emission crap, will it mess with the computer on the 85?
Old Feb 16, 2008 | 08:28 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
www.summitracing.com Look at the Hedman Elites without smog.
HED-68448 $388.00 ceramic coated long tubes.
Old Feb 16, 2008 | 08:34 AM
RRT vette's Avatar
RRT vette
The ECM controls the solenoids for the AIR but it want throw a code if deleted. The AIR only inducts air into the cat at warm up. Once the ECM is closed loop it really doesn't play a role. I've heard/read good things about the hedman elite headers. Around $350+.
Old Feb 16, 2008 | 11:01 AM
vader86's Avatar
vader86
Remove and toss the AIR system, no big deal. That wont affect the computer at all.
EGR in 85 is internal, so the only modification required is to patch up the hole in the header pipe thats made for EGR of later years. It'll need to be welded closed.
Old Mar 6, 2008 | 01:02 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Actually, those say thermal coated. Because ceramic coated is also listed as a category, I'm guessing this coating isn't as good? Why else would they have a ceramic-coated header with a skimpy 1/4" flange for $200 more!
Would you want to recoat (ceramic, jethot, etc...) this type of header? How do they hold up compared to ceramic or other coatings?
gp
To Headers!
