Anti-Lock Light On
Old Feb 24, 2008 | 06:09 PM
All2kool's Avatar
All2kool
Default Anti-Lock Light On
'86E. Noticed it leaving the Golf Course today. Turned the car off and restarted at the first red light, Anti-Lock still on. Brakes feel fine. I didn't even know our cars had ABS.
What to check first?
Old Feb 24, 2008 | 07:00 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
First year, probably one of the sensors is dirty. Check the wires and connections on all four wheels. I can't remember how to pull the codes.
Old Feb 24, 2008 | 10:04 PM
jfb's Avatar
jfb
Check the 10 amp brake fuse. Then call around to Chev dealers and see if any have the Bosch ABS tester which will diagnose your ABS and indicate where the problem is.
Old Feb 24, 2008 | 10:54 PM
C4boy's Avatar
C4boy
The Kent-Moore tester is definitely the easiest way to find out what's wrong in the ABS system, or at least point you in the right direction. It can be any one of a few dozen ABS inputs that set off the light. I bought the Kent Moore tool, If you were local I'd give you a hand with it. Without a doubt you need the shop manual for this. Yes, '86 was the first year for ABS. You will only notice a difference in the braking if you go into a skid - the ABS will no longer pulse the pedal if the light is on, that's it.
Old Feb 24, 2008 | 10:56 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
My light went on 10 years ago, and a quick fix=remove the bulb, that solved my problem.
Old Feb 25, 2008 | 12:54 AM
86PACER's Avatar
86PACER
Top off brake fluid level.
Check "Brake", "Guages", "Stop/Haz", and "INJ 1" fuses.
Read this:
http://www.corvettefever.com/howto/19239/index.html
If that don't work:
Old Feb 25, 2008 | 12:55 AM
86PACER's Avatar
86PACER
No codes on pre 90 ABS.
Old Feb 25, 2008 | 01:19 AM
zr1fred's Avatar
zr1fred
Great I was afraid it was just something more I'd forgotten!
Old Feb 26, 2008 | 02:51 PM
All2kool's Avatar
All2kool
Well that's a head-scratcher. Drove the car today, no Anti-Lock light. Huh.
Old Feb 26, 2008 | 04:06 PM
zr1fred's Avatar
zr1fred
Probably got some dirt/mud/whatever between the sensor and the hub.
Old Feb 26, 2008 | 04:16 PM
All2kool's Avatar
All2kool
Changed the Spark Plugs (in less than 40 minutes), took a drive, Anti-Lock on again, Temp now never goes off LOW. Tell me, the Temp Sensor is nearest the Spark Plug that is nearest the firewall on the passenger side isn't it? I thought I felt a loose wire but forgot to find its connector.
Argh!
Old Feb 26, 2008 | 04:19 PM
Lars87's Avatar
Lars87
And you stop just as quick in rain or on dirty roads, so no problems there.....
To Anti-Lock Light On
