Sensor Location
Old Mar 2, 2008 | 12:41 AM
illenema's Avatar
illenema
Default Sensor Location
I have a 1996 and was hoping someone could help me identify this sensor.
Its on the passenger side placed about between the back 2 spark plugs. Small single wire leads to it. its about the size of a small socket 3/8"
previous owner mentioned needed heat sensor, could this be it? Thank you for the read.
Old Mar 2, 2008 | 12:46 AM
RRT vette's Avatar
RRT vette
Got a pic?
LT1 or LT4?
Is it mounted in the head or block?
What color wire?
My guess is the analog coolant gauge sender.
Old Mar 2, 2008 | 01:01 AM
illenema's Avatar
illenema
Default Sensor
Originally Posted by RRT vette
Got a pic?
LT1 or LT4?
What color wire?
Yes i bet thats it. as the analog meter don't read but the digital works.
looks like its head level, black wire. LT-4
Old Mar 2, 2008 | 01:05 AM
RRT vette's Avatar
RRT vette
Make sure it is what we are talking about. If so, you can take the wire off and ground it on the exhaust manifold/header and turn the key on. The analog coolant gauge should read full scale...all the way hot (260+). When the wire is diconnected it should read 0.
Old Mar 2, 2008 | 01:16 PM
96GS#007's Avatar
96GS#007
Coolant temp sender for the analog coolant temp gage.
Old Mar 2, 2008 | 01:21 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
To Sensor Location
