700R4 Problem
I recently noticed that I lost engine braking in first second and third, it has engine braking in OD.Reverse also works fine. Other than that it shifts very firm and holds full engine power (390 rwhp LS1) Any tranny guys out there? For some reason im thinking valve body related... If its ok to drive it like that I will. Just as long as im not doin any other damage by doing so.
thanks!
-Pat
thanks!
-Pat
Greetings Pat,It would seem you've wandered in to the C6 (2005-2008) Corvette section of the forum. You might have a little better luck if you post this request in the C4 section. You can find it here:
http://forums.corvetteforum.com/forumdisplay.php?f=34
