Engine and Tranny advice
option 1:
Look for a used ls1 and T56 with low miles.(i can find one already in a firebird or camaro for around 2.3k)
Could you tell me how much it work cost me for everything else beside the wiring and computer.
option 2:
I have a friend with a LT1 and T56 for 1.6k with low miles.
also how much other things will cost me cause what is in it right know wont fit into a corvette (coming out of a firebird.)
option 3:
Just rebuild my L98 and 4+3 tranny.
how much would it cost me to rebuild the engine and tranny.
http://forums.corvetteforum.com/show....php?t=1958886
If it was me Id sell the car and move on. For $5,500 you can get a good car. 2k might fix your motor but not with the 4+3.
Find a wrecked car and use it for parts.
Rebuild your L98.
Use the 4+3 for a boat anchor.
You might do a search for the LS1 swap so you'll know what you're getting in to. It might not be a bolt in.
When you run into a wall that you can't climb over its some times better to go around it.
Anyway its a lot to think about. Good luck with whatever you do.
http://sfbay.craigslist.org/sby/car/595415657.html
Option #2 would be to upgrade to a LT1/T56 that would be in your budget range. You should be able to get all of the parts from a donner or even the Chevy dealer ($$$). And would be a good step up. It might only be a bit more than rebuilding your L98 and 4+3.... Again, you would have to deal with the Smog updates of using a newer engine and equipement and getting certifed as to the newer LT1 engine standards.
I don't mean to bring this thread down, but I would look for another C4 in good shape for only a few thousand more dollars.
Sell your current vette, or keep it and use it as a parts car.
On the other hand you may have a vision for this corvette, and money and time are not an issue.
My hats off to you if that is the case.
I would put a 6 speed in it from a newer C4, or install a TKO 500 from Keisler Engineering "like I did".
I would build the L98 up to the level of performance desired. The L98 will be m,uch easier to deal with in every way. You can get as much performance out of the L98 as you will ever likely need or want.
He is the best at the 6 speed conversion. He has done all the leg work for you. If you can find Central Coaster, he has all the best documentation for converting to a late C4 6 speed into a early C4.
He was banned from this site and some really great information left with him.
He can be found at another corvette site.
http://www.corvette-guru.com
If you want to go to the Tremec TKO 500, then Keisler Engineering has a perfect fit kit. It is the best way to go if you want a TKO 500 or TKO 600.
Richmond makes a 6 speed for the early C4 too.
It is a much older design than the other transmissions, has shift rods instead of the enclosed design like my TKO has.
I have not seen a Richmond 6 speed, but I am sure it is a good transmission too.
I went with the TKO because Keisler Engineering is known to be a great company with good support.
If I had of known Central Coaster had procedure documented as well as he does, I might have swapped in a late C4 6 speed. It is cheaper that way because you can find used transmission and parts.
More leg work, but cheaper.
All in all I am more than happy with my TKO, it cost more, but it was brand spanking new when I installed it. It is also a lot more heavy duty than the others.
Good luck.
Good luck.
that site isnt working for me hasnt been working for the past couple days. is the TKO 600 a 6 speed?
TKO 600 is closer ratio between 1 and 2nd.
Both are great.
The TKO 600 is rated at more HP, but they both have the same strength everything. That is what the engineer at Tremec told me.
He said the TKO 500 is just as strong, made with just as strong of internals.
I can only guess it is a marketing ploy to get you to pay the extra bucks for the 600.
Or maybe the closer ratio somehow makes it handle more hp..........I don't see how it could make much of a diff.
Make the ZF upgrade and put a converted LT1 intake on, first gen SBC much easier and cheap to mod. You can do a a stroker relatively cheap these days.You will spend a bundle making the LS conversion work evenif you already have the motor/trans.
Is your user id the same on Guru as it is here on CF? If it is let me know and I will tell Bogus that your user id is having problems. Try again after he has a chance to resolve any issues you may have with your userid.
You did notice the address has changed didn't you. Maybe you might need to clear your temp. internet files too.
I just checked on the Guru forum. Central Coaster answered your transmission swap question.
Have you seen it yet?
I thought you were pizzed at me for something. Like maybe I was going on to much about my TKO 500.
Heck, its about the only thing I know anything about. LOL
I guess I am a little grumpy lately.
Please accept my sincere appologies.
