Fuse box schematic
Old Mar 14, 2008 | 12:12 PM
zip46's Avatar
zip46
4th Gear
Default Fuse box schematic
Have a voltage leak and have isolated it to a silver metal fuse unit when unplugged make the voltage stable...If left in can hear a clicking noise and pulses the battery charger...also drains the battery in one night...need help to identify what this link controls...Thanks zip46
Sorry 1986 vette
Last edited by zip46; Mar 14, 2008 at 12:13 PM. Reason: forgot to put in year of veh.
Old Mar 14, 2008 | 12:28 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Try the FSM
Old Mar 14, 2008 | 12:46 PM
kalister1's Avatar
kalister1
Where is this thing?
Old Mar 14, 2008 | 02:00 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Which Breaker is causing the problem?
There could be 4 of them in the fuse panel. They should be labeled.
Top to bottom.
Breaker for the Rear Hatch
Breaker for the Defogger
Breaker for the Power Windows
Breaker for the Power Door Locks and Power Seats. (ACCY breaker)
Do all of the Power seat functions work?
Do the Power Door locks work?
If the Breaker is for the Power ACCY you could have a stuck power seat switch or pinched wire in the power seat harness.
Unhook the bottom seat cushion and feel of any of the motors are hot.
Old Mar 15, 2008 | 08:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Fuse%...%20Details.pdf
Old Mar 15, 2008 | 11:14 AM
zip46's Avatar
zip46
4th Gear
Thanks everyone for the input...The fuse is located in the forth spot going down in the fuse box...I believe it might have to do with the seats after reading the posts...Will try to isolate further again thanks for the help...Still looking for a schematic...also anyone know of the vin numbers for the konner vettes Thanks Bob
Last edited by zip46; Mar 15, 2008 at 04:27 PM. Reason: hit wrong key when typing konner
Old Mar 15, 2008 | 11:26 AM
zip46's Avatar
zip46
4th Gear
Thanks Agent 86 for the sch...Much appreciated...Bob
Old Mar 15, 2008 | 12:29 PM
AGENT 86's Avatar
AGENT 86
If you need a specific schematic, PM me and I will upload it.
Old Mar 16, 2008 | 07:52 AM
zip46's Avatar
zip46
4th Gear
Thanks again for the great info...I could use a schem. of the ground connection points on a 1986 vet. Still having trouble with inst. Cluster going out intermittingly...Thank again Bob
Old Mar 16, 2008 | 08:44 AM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/agent86/Grounds.pdf
http://members.shaw.ca/agent86/Instr...%20Cluster.pdf
To Fuse box schematic
