bulb ?
Old Mar 30, 2008 | 05:08 PM
denvervet's Avatar
denvervet
Default bulb ?
do i have to pull the digi cluster to replace the bulb for the speedo its the one on the top left .do I take off the crome cover over that bulb thanks in advance
Old Mar 30, 2008 | 07:12 PM
86PACER's Avatar
86PACER
It depends if the bulb holder is broken or not. So remove the front trim, then remove the silver heat cap and see.
If the bulb holder base not broken or missing, you can just gently pull the old bulb out with pliers, and gently press the new one into the existing base all from the front.
If the base is broken or missing, you need to pull the cluster, open it, split the two circuit boards, and twist new bulb with holder into place from behind.
Old Mar 30, 2008 | 08:13 PM
denvervet's Avatar
denvervet
Do you just twist and pull the heat cap then pull straight out the bulb?
Old Mar 30, 2008 | 08:58 PM
86PACER's Avatar
86PACER
Pull both straight out towards you. I used needle nose pliers.
To bulb ?
