Fitting into a C4?
Old Mar 31, 2008 | 11:10 AM
Phantom_Vette1's Avatar
Phantom_Vette1
Default Fitting into a C4?
hey, i am from Perth, Western Australia
i have been in love with vettes since as long as i can remember, i have also like the 78, but then found the 82. But since i sat in one i found there to be very little space. Head on roof, knees between steering wheel and door :-(
Anyway i am 6 foot 6 inches tall and was told that i would fit better in a C4. Ever since i look at the C4 specifically the 1990 model( cos i like the concave tail and better dash) i really want one of those. After 1990 they changed to convex i think.
My question is are there any guys/gals my height that fit well into C4's.
Also would a manual be okay(with knee room etc...) or would i have to settle for an auto?
thanks
Old Mar 31, 2008 | 11:23 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I had a buddy here who was 6'6" and he had a convertible C4 that he fit in.
I'm 5'9" and my head hits the roof sometimes, especially with my helmet on.
Sweet 90's Avatar
Sweet 90
G'day mate Welcome to the forum
I'm 6'-1" and I have a inch or so head room to spare in my 90 coupe.
You should find one and sit in it as C4's are one of the hardest to get into or maybe a tall forum member will chime in.
ps: you should fill your profile in when you get a chance
Jim
Old Mar 31, 2008 | 11:31 AM
cv67's Avatar
cv67
St. Jude Donor '05
A C5 would fit you better, 6'6" is tall!
Old Mar 31, 2008 | 11:41 AM
78pacer's Avatar
78pacer
I fit with a lil' bit of room to spare. 6'4" 245lbs. My pacer is a sardine can compared to the '95. Much less room. The '95 is a 6 spd and I have no trouble shifting. Enjoy !
Mike
Old Mar 31, 2008 | 11:55 AM
Troy.Blackburn's Avatar
Troy.Blackburn
There are several variables here and so it's not as simple as just how tall you are, so the recommendations that you find one to sit in are right on the mark.
Leaving the car out of the picture for a moment, some of the variables are how much you weight and how long your legs are. I'm 6' 2" 250lbs and I fit fine in mine. I've got a friend that is 6' 1" who tried to get in the passanger seat once and his head was bent over, hitting the roof... the problem was he's a very big guy and sat much too high in the seat.
The seats on many of the C4's are narrow and so the slimmer you are, the lower you will sit in the seat, and of course the bigger you are the higher you will be.
You can also gain some head room on a coupe by using a Clear Targa Top vs the Painted Top. The Clear Tops do not have a headliner and so give you more head room.
What size shoes you were can also effect things. I wear 13W and on long drives I have to slide my left foot around the left side of and then behind the clutch pedal to get confortable. It's a bit of a tight fit, but I've done it so much I don't even think about it anymore. A car with an automatic would give me more room for my left leg to stretch without doing this.
If possible, sit in a manual and a automatic car, both with the clear top installed, see how it feels. Even though you prefer the 90 vette, if you have the opportunity, sit in a later 90's C4. The seats are not as narrow in some of the later C4's so you may sit lower. Depending on your build, you might find that putting some later C4 seats would help you fit more comfortably in a 90.
Old Mar 31, 2008 | 12:06 PM
94flavette's Avatar
94flavette
I'm 6'8" and I really have to squeeze in. For me it's managable but I had to get used to my knees against the bottom of the dash.
I find it to be more comfortable if I move the seat forward a little bit (yes, forward) so that I can tilt the back at a greater angle for more headroom clearance.
I know a c5 has more room, but a c4 is what I always wanted so I can deal.
Old Mar 31, 2008 | 01:42 PM
mdlfcrss's Avatar
mdlfcrss
6'3" and 280lbs. No problems with the targa top on...however, it's a little cramped with the painted roof on.
Old Mar 31, 2008 | 01:46 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I'm 5' 10" and with the painted targa with the headliner I have about an inch to spare.
This is due to the fact that I just put in new seat foams and covers.
With the originals I had about 2" to spare.
The glass targa gives a little more room.
Old Mar 31, 2008 | 01:47 PM
Digital Disaster's Avatar
Digital Disaster
I'm 6' with long legs and could really use an extra 1 - 2" legroom. It's the only thing I really dislike about a C4.
Old Mar 31, 2008 | 02:07 PM
collector man's Avatar
collector man
I'm 6'7" @ 230lbs, I fit in my car ok. Just adjust the seat bottom to it's lowest position and tilt the angle of the seat untill it max out.
Old Mar 31, 2008 | 02:09 PM
Sweet 90's Avatar
Sweet 90
Good God we have some tall drivers
Old Mar 31, 2008 | 02:58 PM
NEVRL8T's Avatar
NEVRL8T
Same here.
Old Mar 31, 2008 | 04:43 PM
Matt Cramer's Avatar
Matt Cramer
I'm "only" 6'2" tall, but I have trouble with my helmet on for racing. With no helmet it's quite roomy although I do worry I might clunk my head on the main hoop in an accident.
Old Mar 31, 2008 | 06:42 PM
Caboboy's Avatar
Caboboy
I'm 6-1 & I gotta do the gangsta lean with a helmet on. Especially now with new foam in the seats
Old Mar 31, 2008 | 08:20 PM
Jim Nichols's Avatar
Jim Nichols
I'm 6'5, 275 and 61 years old. Got some tightness in my left leg due to a AK-47 round in Vietnam...I can still get in and out of a 91 Coupe.
Old Mar 31, 2008 | 09:06 PM
94 whezzer's Avatar
94 whezzer
I'm 5' 8 and getting in no problem except smacking my head on the top will I'm falling in, maybe I should wear a helmet while I'm getting in, then once in finally in it seems the car was just built for me!
To Fitting into a C4?
Old Mar 31, 2008 | 11:21 PM
djpatrick35's Avatar
djpatrick35
6'6" - 300 pounds here.
(36" inseam, size 16 shoes if anyone's counting)
And I fit into C4s just fine. The only problem is '90-'93 sport seats with controls on both sides are pretty uncomfortable on long rides. So I bought '96 seats and those are just perfect. At <our> size, I think it feels nice the way the car wraps around you.
Also, I have a '90 ZR-1, so I also have a stick. There's not too much room for big feet, so you kinda have to rest your left foot on the clutch, but honestly with feet my size, that's no different from most other cars. I say take one out for a test drive (and don't forget to put the seat all the way back before you get in!) I promise, you'll love it.
Besides, I ALWAYS love seeing people's eyes bug out when my big *** accordions out of a freaking C4 Vette!
Old Apr 1, 2008 | 12:36 AM
corvettedan22's Avatar
corvettedan22
djpatrick, are you hulk hogan ?
Old Apr 1, 2008 | 01:41 AM
xrcrx's Avatar
xrcrx
I'm 6'2" and my 84 is perfect even on long road trips. however, when at the track i have little clearance between my helmet and the top.
