Courtesy Lights
Old Apr 8, 2008 | 03:58 AM
SpeedyKev42's Avatar
SpeedyKev42
Default Courtesy Lights
The courtesy lights on my 88 Corvette will work when I turn the headlight **** on the dash, but they will not come on when I open either door. The door ajar light comes on when I open either door. So, I think that the door switches are good. Is there something else that I should be looking at to get the courtesy lights to work?
Old Apr 8, 2008 | 05:44 AM
Dostovel's Avatar
Dostovel
Mine acted up briefly when I washed the car... this only happened lately and it was a couple times only. My door ajar light would flash as well when I would turn a corner or accelerate fast. I have no idea why, it only happened after I washed the car. Maybe it was because it was wet, I have no clue. Does it happen all the time for you?
Old Apr 8, 2008 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Courtesy light delay timer.
http://members.shaw.ca/agent86/Interior%20Lights.pdf
Corvette Central sells the timer or you can bypass it. Use the search engine, you will find lots of threads, some with bypass and repair info.
Old Apr 8, 2008 | 11:54 AM
pmihaltian's Avatar
pmihaltian
Slingshot
You most likely need to replace your Courtesy Light Delay Timer. You can get one on eBay http://cgi.ebay.com/ebaymotors/1984-...spagenameZWDVW
Here is where the relay is located under the passenger side dash.
File Type: pdf
To Courtesy Lights
