Planning a pull for HP & Torque. In addition another pull for lapsed timed 1/8 mile. Will do the driving on the rollers myself. How 'bout some tips on throttle techniques and shift points thru the gears. Driving a 94 6 speed
w minor mods. 53MM TB, Vortex Forced Air, Borla Cat Backs, 8K on new Jasper LT1 & ZF Tranny, Hurst Short Shifter.
My dyno guy has new Mustang dyno equiptment.
Unless you're also going to be doing some tuning there won't be much shifting needed. When you're making a dyno run the operator will usually take it to 4th and run it WOT until a specific RPM of he hits the rev limiter.
Be for-warned, if you're going for numbers Mustang Dynos normally read a bit low. Try not to get into to much dyno-sheet-racing.
