Ay Carumba!!!
My goal was to find out what was wrong so that I don't just keep throwing piles of money "under the hood." So, anyway, the Chevy Specialist had my Vette for the whole day and called me at about 4:00 in the afternoon. His comment (and this is a quote), "The only code in the computer is a rich condition. We see nothing to cause this and we can't read live data in this age vehicle. The [rough] idle is normal for these LT1 engines. Know of no known cure for it." I have posted a picture of my LT1 engine below.
This guy must be joking ... except it isn't April Fool's Day.
Honestly, it is really bad when I know more about the car than the Chevy Specialist.Needless to say, I will continue my quest to find a service/repair shop where the mechanics know what they are talking about. I guess I need to go to a different bar and hang out with some other people.
I think he is politely giving you the elbow, and does not want to work on your car. The fuel injection system is remarkably similar to a cavalier of lumina.
Even the local Chebby dealer out here says they dont deal with/remember about OBD 1 cars. Keep looking, a good running TPI will idle nice and smooth. Not as silky as an LT1 but pretty darn good.
These valves are integral to your idle control.
Buy some GM intake cleaner ($10-$15)and follow instructions to the LETTER.Totally solved rough idle on my 93 4.3 vortec.
Good Luck
He could be on to something. running rich I mean. These are the old single wire O2 sensors, right? Also if the water temp sensor is going south and giving a false reading to the computer it will stay in open loop. Both of these two things will cause it to stay in open loop which is not a bad thing for top end power production. But it does fudge up the lower end due to excessive heat (normal op temp) which it would go closed loop at that time.
Have you ever used any type of silicone from the aircleaner back?? Any, and I mean ANY silicone will pump thru the system and fudge up the O2 sensor, which will cause it to give false readings.
One last ditch effort is the fuel pressure regulator is stuck at full pressure while at idle and the computer cannot get the injector dwell low enough to compensate for it.
All three scenarios are relatively cheap.
J
J
