Need help identifying engine!
Old Apr 9, 2008 | 02:43 PM
mattdado's Avatar
mattdado
1st Gear
Default Need help identifying engine!
I'm new to corvettes and need help identifying this engine..
Not sure if its a corvette
This motor is installed in a 88 GMC Serria
Old Apr 9, 2008 | 02:46 PM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
thats an l98
Old Apr 9, 2008 | 02:47 PM
Goldcylon's Avatar
Goldcylon
Look like a base model L-98 to me
Old Apr 9, 2008 | 02:55 PM
C4boy's Avatar
C4boy
Ditto. I'd guess it's an 87-89
Old Apr 9, 2008 | 04:04 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Sweet. I so want to do that to my 89 Chevy c1500!!!!! Good find.
Old Apr 9, 2008 | 04:48 PM
TPIGUY's Avatar
TPIGUY
Easiest way to tell the diff between Corvet and Camaro TPI is this... On the Corvette motoe the fuel rails (connections) come out of the front left (pass) side of the motor as you are looking at it, the Camaro fuel lines come out of the right hand (drivers) side. Yours looks like a L98.
Old Apr 9, 2008 | 07:14 PM
Greg0u812's Avatar
Greg0u812
That corvette emblem on the valve cover doesn't give it away????
C4boy......could've also come out of an '86 (at least my '86 has the aluminum head l98 in it).
Old Apr 9, 2008 | 07:48 PM
Calderone's Avatar
Calderone
Could be just the covers or just the heads + covers
and it can be a 305 if it was on a GMC Sierra (i dont know for sure if the Sierras came with 305's)
Old Apr 9, 2008 | 08:05 PM
VetteMed's Avatar
VetteMed
No MAF sensor, only MAP, so it's probably from a 90-92 F-body, If I remember my thirdgen trivia correctly.
Old Apr 9, 2008 | 08:12 PM
cwyates4's Avatar
cwyates4
90-92 fbodys were map systems, but that could just be the induction system on a 305 as mentioned before. If the engine was pulled from a fbody and is a 350, then the code 638 should appear on the driver's side (I think, could be pass. side) of the block by the freeze plugs.
Old Apr 9, 2008 | 08:24 PM
Calderone's Avatar
Calderone
we'll see what it is....
i think the vette emblem its just for looks
Old Apr 9, 2008 | 08:36 PM
TPIGUY's Avatar
TPIGUY
Looking at pictures I see the fuel lines commimg off the drivers side just behind the alt. TPI is camaro/firebird type, probably 305 maby 350.
Old Apr 9, 2008 | 11:19 PM
C4boy's Avatar
C4boy
I think you're in the right ballpark. The MAP sensor is why I ruled out '86, but wasn't sure what year switched from MAF to MAP.
Name that motor continues!
Old Apr 10, 2008 | 12:32 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Theres a few different things I detemined.
Its definatly a 90+ F-body TPI.
Its not a vette motor, those dont look like 113 heads.
The ceterbolt heads mean 87+ bolt pattern, vette intake base wouldnt
work.
It has a small cap HEI with the external coil (F-body or Truck)
F-body fuel rail.
Its either the truck motor with an F-body TPI and vette valve covers.
Or its an F-body motor with vette valve covers
Or it could be a one off build that someone did with a TPI, and theres no telling.
The only way to be sure of the CI is to check the casting #'s
Old Apr 10, 2008 | 04:39 AM
rodj's Avatar
rodj
work.
F-body fuel rail.
Engine underneath has no relevence to what is bolted on top.
Anything can be mixed and matched on a SBC.
Front access are not Vette ; has normal rotation water pump and idler in non Vette L98 location.
To Need help identifying engine!
