Starting issue please help
Old Apr 14, 2008 | 12:23 AM
braves7421's Avatar
braves7421
8th Gear
Default Starting issue please help
I have a 1990 c4. It has an intermitten starting issue. Most of the time it starts perfectly and runs great. Occasionally, I turn the key, dash lights light and nothing. I wait at least 5 minutes and it starts perfectly. I have replaced Vats ignition key, no change. I have purchased a prom designed to bypass the Vats system, no change. I believe it is in the vehicle security system due to the wait time. Any info on trouble shooting or by passing security system would be greatly appreciated. I love the car and cannot depend on it.
Old Apr 14, 2008 | 09:17 PM
braves7421's Avatar
braves7421
8th Gear
I fixed it. It was the starter enable relay.
Thanks for all the help.
Old Apr 14, 2008 | 11:25 PM
jfb's Avatar
jfb
I don't know when you put up your post, but you shouldn't expect the entire planet to jump on your question immediately. I check in here throughout the day and am on late at night and I only just read your post. Glad you found your problem, I suggest you exercise a bit more patience!
To Starting issue please help
