Dash pad delete pics
Old Apr 20, 2008 | 09:35 AM
7thvet's Avatar
7thvet
I think the bread box was caused by Ralph Nader.
There is another replacement with a leather map holder that looks better IMO.
Old Apr 20, 2008 | 10:05 AM
Aardwolf's Avatar
Aardwolf
Originally Posted by Syclone354
Andrew that gauge up in the vents looks great, is that something you made or is the gauge plate something you can buy?
I made that, it was a simple project. The dash vent pops out then a square flat piece of black plastic is needed to go around the gauge. I cut that from a container I had laying around. The gauge is my trans temp, I have an oil pressure gauge to go along side of it. That I am adding so I don't have to flip the switch from oil temp to oil pressure on the track.
I've put black polish on the wheel but I think my driving gloves rub it off from track driving.
Having the flat panels makes it easy to work under that area which has saved me a lot of time. Just three screws by the fuse box and the panel comes out.
Old Jun 9, 2008 | 10:38 PM
ekess744's Avatar
ekess744
Does anyone know how much the breadbox weighs? Im curious before I tear into the dash completely. if its not that heavy I'll just leave it alone. It looks massive! The delco radio was way heavier than I expected.
Old Jun 9, 2008 | 11:08 PM
Greg0u812's Avatar
Greg0u812
Originally Posted by ps374
...... John delorean also had it built and wrapped in leather in the DMC 12 back in 1981. Remember this was before air bags were mandatory and the DMC 12 as poor as it was put together was a car 10 years ahead in design of most of the rest of the cars built in the 1980s.
I thought he used the space behind the dash pad for.............ummmm.......never mind.
Old Jun 10, 2008 | 01:55 AM
floridamale's Avatar
floridamale
I never liked the look of the bread box
Just my opinion
Old Jun 10, 2008 | 08:08 AM
Syclone354's Avatar
Syclone354
its not very heavy. not a mod i would do to save weight. It does give the passenger a lot more room though. My girlfriend imediately said she felt like she had more room.
Old Jun 10, 2008 | 08:24 AM
skeet2low8's Avatar
skeet2low8
Seeing as my primary passenger is my 13YO son and the car has no air bags, I think I will keep the "Breadbox".
Old Jun 10, 2008 | 08:31 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Just my opinion
Nice touch, your interior looks great!
Old Jun 10, 2008 | 09:39 AM
Aardwolf's Avatar
Aardwolf
For when he doesn't wear his seat belt?
Old Jun 10, 2008 | 11:52 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I picked up a used one with the idea of converting to a glove box and was surprised at how light it was. It's mostly hollow expanded foam with a little steel frame; I would estimate 2-3lbs tops tops.
Old Jun 10, 2008 | 01:50 PM
floridamale
Thanks yours looks clean as well my last vett had red gutts.
Old Jun 10, 2008 | 01:52 PM
jhammons01's Avatar
jhammons01
My recolection is that the passenger side Airbag was not ready in time...so we wound up with the pillow.
That would make sense if the '85 or even '86s had an actual airbag inside the pillow...so I doubt my version of why the pillow is there.
I gotta get rid of that thing. I just haven't had extra time to address it.
Old Jun 10, 2008 | 02:00 PM
  #33
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by WW7
I see your steering wheel is wearing, If you want it to look new again get some black paste shoe polish, rub it on, let it dry and it will look great again and will last for a pretty long time. WW
Works great !
Old Jun 10, 2008 | 02:55 PM
  #34
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Originally Posted by Spankyellow
Vin, put on your glasses. He removed the bread box.
Duh, he said dash pad, not breadbox.... i'm old but can still read
and yea, i do like it better without the BB, deleted mine long ago
Old Jun 10, 2008 | 04:15 PM
  #35
ekess744's Avatar
ekess744
thank you
Old Jun 10, 2008 | 06:23 PM
  #36
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I did a search but I did not find it. I was trying to find a guy that about 5 years ago in the Corvette Action Center web he tried to "open" the bread box because he tought it was really a compartment for bread, he was slaughter with sarcastic comments.
...for the forhead I think the bread box was a L-83 feature
Old Jun 10, 2008 | 06:30 PM
  #37
skeet2low8's Avatar
skeet2low8
If seat belts really protected you, why did they make AIR BAGS! Should have and use both.
To Dash pad delete pics
Old Jun 10, 2008 | 06:40 PM
  #38
Aardwolf's Avatar
Aardwolf
I agree. BTW why are you putting your boy in a car without one then? Stop hijacking the thread!
Old Jun 11, 2008 | 12:00 AM
  #39
PLRX's Avatar
PLRX
2017 C4 of Year
This is a Y2K subject. .......To create jobs.
Now they have side airbags. Soon we will have something like the Stallone movie, the one he was frozen, he was de-frosted to fight "Blade", the car got into a crash and foam filled the inside of the vehicle.
Anyway, Syclone, your Vette looks great!
Old Jun 11, 2008 | 12:50 AM
  #40
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Made my own on a previously owned 87. Cut a piece of thin plywood from scrap laying around the garage. Went to an upholstery shop who gave me a remnant of white vinyl and leftover padding. I cut the hole for the AC vent then sprayed the vinyl with interior dye and installed it. Most expensive part was the emblem that I got from Corvette Central.
Like the upper dash pad that I also dyed with the same spray dye? Kids, don't try this as home as it reflected badly off the windshield. I purchased a used stock dash pad from Vette2Vette and put it back to stock after only a few weeks.
