Explosion!
Old Apr 20, 2008 | 06:35 PM
OzzyC4's Avatar
OzzyC4
Default Explosion!
Turned on the key to my 87 coupe, then proceeded to roll it into the start position.
At that moment I heard an ear ringing (still ringing over an hour later) explosion.
I stood up (was kneeling on the floor next to the car with the door open) and looked forward and saw what at first appeared to be smoke coming out from under the hood.
I quickly open the hood and expect fire, but luckily there isn't any.
What I did find is an exploded battery.
Car has not been driven in 2 years, but has been started infrequently during that period of time as I move it in or out of my shop.
Once or twice a year I have put a 2 amp charger on it when needed.
What I believe happened is the battery had lost a lot of its water, leaving a large head space in the case. That space filled with hydrogen gas and exploded when the battery was subjected to the starting load.
Yes it is MY fault for not checking the water, I just assumed it was fine knowing its use history. How WRONG I was.
The lesson here is be sure to keep an eye on the fluid level in your battery.
Old Apr 20, 2008 | 06:44 PM
KBoltz's Avatar
KBoltz
As long as you are ok - the battery and other damages can be repaired/replaced.
Damn. Time for me to seriously look in to an Optima battery.
Old Apr 20, 2008 | 07:22 PM
newbecorvetteguy's Avatar
newbecorvetteguy
You're correct about the hydrogen making the kaboom. It takes a spark to ignite it though. Load wouldn't have done it. A short between cells could have generated an excessive amount of gas. Probably a broken connection inside the battery made the spark. Odds are you wouldn't have been able to predict this outcome no matter what you did. Rinse everything off with either battery cleaner or baking soda and water to stop the acid from eating other things.
Old Apr 20, 2008 | 07:33 PM
jordanpingrey's Avatar
jordanpingrey
Well thanks for taking one for the team. I store my car for long periods of time as well, but I put a new battery in it before i stored it. I need to check that water again when I get to her, wow I'm just glad you didn't have the hood open and someone else starting it or some situation like that. Glad your safe!!!
Old Apr 20, 2008 | 07:52 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Damn, just damn, glad your ok, get a new battery & drive that Vette.
Old Apr 20, 2008 | 08:22 PM
RACER 1993's Avatar
RACER 1993
Holy Cow. Iv'e seen one catch fire before but I have never seen one that exploded. Be careful out there.
Old Apr 20, 2008 | 08:40 PM
or92vette's Avatar
or92vette
JEEBUS!!! INCOMING!!!
Glad yer OK!
Old Apr 21, 2008 | 02:10 AM
rdcamero's Avatar
rdcamero
They really pack a punch when they blow.A couple a years ago a guy at work was checking one on the parts counter when it blew.It sounded like a shot gun went off.He got lucky.He seen a small spark and closed his eyes just before it blew.
I had one blow up with me about a year ago.A guy comes in with one in a straw blower.The battery had slid under a metel bar that was putting a dead short on the battery.It had been that away for a while so i figured it must have shoted out and not have any charge left in it.
I was wrong.I started to take the cable loose and there was a really loud boom.I don't remember seeing any thing just the noise.I turned my head a split second before it went off.I am not sure if I saw a spark or what made me turn away.I was lucky and did not get any acid on me, but the two guys that brought it there got covered in acid.It shook them up pretty good but did not cause any injuries.
Old Apr 21, 2008 | 09:57 AM
corvettedan22's Avatar
corvettedan22
Wow
Old Apr 21, 2008 | 10:00 AM
Demonic85's Avatar
Demonic85
It didnt damage the body panel did it???
Old Apr 21, 2008 | 10:41 AM
Bob88vette's Avatar
Bob88vette
Wow, glad you're ok really. Not to hijack the thread here but does happen to a certain TYPE of battery only? Like an Interstate Battery?
Old Apr 21, 2008 | 12:10 PM
RacerX70CC's Avatar
RacerX70CC
I had one of those blow up in my face when I used to do road service years back... fortunately I was wearing sunglasses (which were blown off my face), and I wound up covered in battery acid. Lucky for me it happened in a restaurant parking lot, so I managed to duck into the restroom and get the acid off my skin before getting any serious burns (it still burned like a bitch, let me tell ya).. The battery was an Interstate, and the cause of the explosion was a loose positive terminal (side post), causing a spark. This condition I still find on Interstate betteries today... the telltale sign is acid leakage.(Globe Union must make them to a different spec for Interstate), and for this reason I'll never run one of those POS batteries in any of my rides, or my clients.
This is just my experiece... YMMV
Old Apr 21, 2008 | 01:20 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Man, 21 years ago that happened to me and a buddy, drinking all night and his Camaro's battery blew like that. Ahh we got it jumped and drove home with no battery. Don't ask me how, read first line, college you know...
Old Apr 21, 2008 | 03:18 PM
Inlove's Avatar
Inlove
Wow, I didn't know that could happen, it's just like you guys to teach me something... It's a wonder my head dosn't explode.
To Explosion!
