antenna mast
Old Apr 28, 2008 | 06:52 PM
clay69's Avatar
clay69
Default antenna mast
hi all has anyone replaced there antenna mast mine got broken off
I have the new mast and plastic strip to replace it.
Can you get to the antenna from inside the car or do you have
to go from under the car?
Anyone with pictures if you could post them it would be great
Any help will be greatly appreciate.
Clayton
Old Apr 28, 2008 | 08:29 PM
seenalot's Avatar
seenalot
For an 89 I replaced my mast by going under the car.
Old Apr 28, 2008 | 08:53 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
take a look at the tech tips ('other' pull down menu, then C4). there are 3 articles on antenna removal.
Old Apr 28, 2008 | 10:03 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
You need the socket to remove the retainer nut if you are doing just the mast and not the unit. My mast came with one. Then have someone turn the radio on and it will shoot right up. Gently pull the antenna out you will see how the plastic gear strip is oriented. Slide new one in (make sure it has the outer stop fitted at the bottom of the mast) it may take a few trys to get the gear and gear strip to align but when you do you can tell. Once you have it threaded have someone turn off the radio and guide the antenna in. Replace retainer nut. Done
It took a couple of days for mine to go all the way down but you can push it down by hand. Mine needed to wear in a little I suspect I bent it a little.
Old Apr 28, 2008 | 10:18 PM
corvettedan22's Avatar
corvettedan22
From under neath !
Old Apr 28, 2008 | 10:22 PM
Redeasysport
Hey guys it is different for a LT1 car if you did not know. I posted the correct way for a mast replacement.
Old May 1, 2008 | 08:01 AM
Da Mail Man's Avatar
Da Mail Man
Originally Posted by corvettedan22
From under neath !
Old May 1, 2008 | 09:42 AM
78pacer's Avatar
78pacer
replace the car...done
Mike
Old May 1, 2008 | 09:54 AM
mdlfcrss's Avatar
mdlfcrss
Mine just broke on my '91 about a month ago. It turned out that the 'tail' had broken inside the drum so I had to remove the entire unit. It was much easier than I expected...I removed the L/R tire, pulled out the inner fenderwell and it was out in ten minutes.
Old May 3, 2008 | 01:05 PM
ps374's Avatar
ps374
On a 84 must the muffler be removed to replace whole unit?
To antenna mast
