Door panel ?????? question ---
Old Apr 29, 2008 | 10:38 AM
jwalters's Avatar
jwalters
Default Door panel ?????? question ---
Riddle me this bat people -
My passenger door panel keeps popping off the upper steel retainer which runs parallell to the window squeegee channel. Are there supposed to be some sort of 'thing' that goes over the metal lips to aid in door panel retention? Like a clip or some sort?? The panel acts like it wants to stay put, but the metal ledge just does not grab it good enough.
Old Apr 29, 2008 | 11:18 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The inside top of your panel is broken. Do a search there is a way to fix it.
This came from The "other" tab at the top under C4 tech tips
https://www.corvetteforum.com/techti...=242&TopicID=2
Old Apr 29, 2008 | 12:18 PM
ynk1121's Avatar
ynk1121
The ribs that hold the door panels shape get tiny hairline cracks in them. Get some "J-B Weld" adhesive and apply a generous coating to the ribs. Rap the panel with some tape to hold it tightly in shape until it dries. It's been holding for me without problems for years.
Old Apr 29, 2008 | 01:35 PM
thebeerman's Avatar
thebeerman
Sounds like the last person neglected to slide the panel down on the top lip before tightening it up. 25 min. job - redo it.
Old Apr 29, 2008 | 03:57 PM
SpeedyKev42's Avatar
SpeedyKev42
Try taking the door panel off and check it for cracks. I had some cracks in mine and I used some stuff called automotive goop to repair it. You can buy automotive goop at Autozone.
Old Apr 29, 2008 | 07:20 PM
96polovette's Avatar
96polovette
There are many creative solutions. Here was mine and still holding....
http://forums.corvetteforum.com/show...ght=door+panel
Old Apr 29, 2008 | 08:44 PM
CAP94's Avatar
CAP94
I don't like to say this but "do a search", there was a forum member who used zip ties and drilled small holes in the ribs inside the door panel. He had step by step instructions and pics.
I tried it and it worked great. Good luck
Old Apr 29, 2008 | 09:37 PM
jwalters's Avatar
jwalters
Thanks everyone for the replies!!!
Glad/sorry to see there are many others with same problem and many remedies to spread...WORD!
J
To Door panel ?????? question ---
