ASM Harness Bar installation?
Old May 5, 2008 | 03:09 PM
wingman4rent's Avatar
wingman4rent
Default ASM Harness Bar installation?
I finally got my used ASM harness bar from ebay and I dont have any instructions for it only the brackets and a few nuts and bolts. Any one put one in their car and can point me in the right direction. Thanks for the help.
Old May 5, 2008 | 03:24 PM
Digital Disaster's Avatar
Digital Disaster
The bar is mounted to the two big shoulder harness bolts, the two small bars coming off the top of the loops bolt on the removeable top bracket.
Old May 5, 2008 | 04:38 PM
wingman4rent
Anyone have any pictures of how the side brackets are mounted, and also how the seat belt it bolted on, I am not sure which side of the bracket it goes on, and how it goes through the slot in the bracket. I will keep searching this site for some pics of there peoples, thank you for the help.
Old May 5, 2008 | 05:44 PM
JCD's Avatar
JCD
Got pictures of yours? I don't know if mines the same or not...
Old May 5, 2008 | 06:57 PM
wingman4rent
Old May 5, 2008 | 07:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The way the last one is pictured is how they would go in. The bracket fits in the hole where the seatbelt bolt goes and then the bolt goes through.
That's how it is on my R-D bar.
Old May 5, 2008 | 10:38 PM
wingman4rent
Ok, so i know which side the brackets go on, now the next question how does the seat belt mount? Does the seat belt mount inside the bracket between the bracket and the B pillar, or does it go between the bracket and the bolt head. Also I noticed the hole in the mounting brackets does the seat belt pass through the holes or are they just there for asthetic and weight saving reasons? Also do i need a longer bolt to mount the seat belt, because I didnt not get any with the bar. Thanks for the help!
Old Aug 18, 2009 | 05:17 PM
93 Aqua Blue's Avatar
93 Aqua Blue
I have a great installed phot but CF won't let me attach or copy paste. If you need it let me know and I will email it to you.
Old Aug 19, 2009 | 07:40 AM
runner140*'s Avatar
runner140*
Call "Arizona Speed and Marine" and ask to be faxed the installation instructions, I did, five years ago. (1-480-753-0208)
To ASM Harness Bar installation?
