Headlight issue???
Old Jun 5, 2008 | 12:50 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Same bushings as a Ford window motor
All the auto parts places have them
Old Jun 5, 2008 | 01:01 PM
bangand0lufsen's Avatar
bangand0lufsen
yeah the teeth of the cork screw gear and the white gear are touching for sure. Those are the only two gears that i see in there. Not sure what black gear you are talking about. now when the headlight is out and on my table and i turn the motor manuly from the top of the motor you can see it moving the headlight but once you put the headlight back in the hood it wont even unlock the motor just spins for 15 to 20 seconds. also if it is the cork screw gear how might i fix that or run a test to make sure thats the problem. Thanks again for all your help im in the middle of a move right now so i dont have internet at home and have to use the work comp so trying to figuar everything out before i head home todo some more trouble shooting.
Taylor Truelove
Old Jun 5, 2008 | 02:22 PM
jhammons01's Avatar
jhammons01
ah! Your motor looks like this??
Old Jun 5, 2008 | 02:25 PM
jhammons01's Avatar
jhammons01
It has to be with that part that comes out of the shaft
See the part that is sticking out 90° or the shaft??
If the motor corkscrew is turning the white gear and the white gear is turning that shaft that comes out of the motor sideways.....then there is something loose or not coupled between that side shaft and the headlight bucket.
Old Jun 5, 2008 | 02:26 PM
bangand0lufsen
yeah looks just like it lol pain to keep those brushes in when putting it all back together but yeah that is it. and when i manually unlock the headlight from being under the hood the light just falls down to the heavyest spot.
Old Jun 5, 2008 | 02:29 PM
bangand0lufsen
yeah i was wondering if the shaft coming out of the white gear is spinning inside the white gear or if it has to do something with the linkage connecting to the shaft outside the motor caseing. and the pin is secure in the shaft of the outside of the motor case connecting the linkage to the shaft.
Old Jun 5, 2008 | 02:35 PM
jhammons01's Avatar
jhammons01
If your motor and white gear are running right and the light is falling to the heavy spot....it has to be the coupling.
I'd start there and see what I find. I guess we'll speak tomorrow after you get back to the innanets...
Old Jun 5, 2008 | 02:45 PM
bangand0lufsen
just so i make sure i am understanding this correct when you say coupling are you talking about the linkage connecting to the shaft coming out of the motor case.
Again thanks for all you help?
Old Jun 5, 2008 | 02:56 PM
bd2626's Avatar
bd2626
http://forums.corvetteforum.com/show....php?t=2043680
See #3 post on this link, may help!
Old Jun 5, 2008 | 03:19 PM
jhammons01's Avatar
jhammons01
this one?
Originally Posted by Quarklt1
Hello
Drill a 1/8 hole through the aluminum puck housing and shaft at one of the three valleys insert a roll pin, puck housing is spinning around shaft
Old Jun 5, 2008 | 03:24 PM
bangand0lufsen
will check that out too. "aluminum puck housing and shaft at one of the three valleys" Can someone describe these parts i know all the parts on the linkage and motor but unfortanitly do not know the tech terms for some of those parts.
Taylor Truelove
"or if there is a pic of that also would be helpful."
