Wheel refinishing
Old Jun 1, 2008 | 08:57 AM
Bill Cude's Avatar
Bill Cude
Default Wheel refinishing
I have come across a set of "89" wheels that need refinishing. Not sure haw to go about doing this, any ideas ?
Old Jun 1, 2008 | 09:21 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Here is an old thread on the subject:
http://forums.corvetteforum.com/show...ed&forum_id=34
Kevin
Old Jun 1, 2008 | 10:00 AM
Bill Cude's Avatar
Bill Cude
What compound did you use ?
Old Jun 1, 2008 | 10:30 AM
Alan777's Avatar
Alan777
If he's using actual paint compound, I'd probably finish up with a polish afterwards.
Old Jun 1, 2008 | 10:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
It was aluminum polishing compound.
Start here for some good info
www.tarheelparts.com
They wil guide you if youre a first timer so you only buy what you need.
One of the few polishing places that actually will give sound advise that is accurate
Old Jun 1, 2008 | 11:13 AM
Pete K's Avatar
Pete K
Write a check. It is the way to fly. Some companies will strip them, straighten, polish, and reclear for $100 each.
Old Jun 1, 2008 | 09:39 PM
eagleye's Avatar
eagleye
I did the wheels on my 89 over the winter. I stripped them, wet sanded them and polished them. The biggest PITA was the paint in the fins. The clear comes off pretty easily but the paint really is a challenge to get. I used a dental pick to get in the corners. Total time was about 100+ hours for the four wheels. Mine weren't bent or scraped up so it was pretty much just a cosmetic refinish. I did not re clear them.
Old Jun 1, 2008 | 09:52 PM
eagleye's Avatar
eagleye
Here are some pics I posted a few weeks back.
Before
After
Old Jun 1, 2008 | 09:55 PM
Bill Cude's Avatar
Bill Cude
Very Very Nice!!!!
Old Jun 1, 2008 | 10:33 PM
yaknow's Avatar
yaknow
I love the look but, at 100 hours the $400. is starting to look reasonable.
Old Jun 1, 2008 | 10:48 PM
Strick's Avatar
Strick
I started to do my saw blades and it took me over an hour to get 2 fins on one wheel to look like a polished shine. I don't think I'll continue with this method. I bought ZR1 5 spokers instead.
Old Jun 2, 2008 | 12:17 AM
Whitecloud's Avatar
Whitecloud
Can you tell me what companies will restore my 87 rims, or what to put in for a search. I like the original look.
Old Jun 2, 2008 | 12:31 AM
Dads90's Avatar
Dads90
Redid mine, I basically gave up on the water spots, what a bitch. The paint went on good and I will probably look into other ways to get the tough spots off.
Old Jun 2, 2008 | 02:32 AM
JimiHendrix's Avatar
JimiHendrix
What kind of paint did you use?
Old Jun 2, 2008 | 10:48 AM
eagleye's Avatar
eagleye
I haven't had any water spot issues with mine. I just keep them polished with Nano Polish and then a coat of wax and they seem to hold up pretty good. I have been caught in the rain a few times plus washing and I haven't had any spots. If your in a hurry to get them done I would suggest having someone do them or buy new wheels. I needed something to do over the winter. I have a 93 with sawblades and luckily they are in very good shape so I won't be needing to refinish them. I would think twice about doing those myself.
Old Jun 2, 2008 | 10:56 AM
Pete K's Avatar
Pete K
There are 2 that I am aware of in northeast Pa. One is Keystone, and the other is Wheel Collision Center in Bath, Pa. I used wheel collision center 10 years ago, and the wheels still look great.
Old Jun 3, 2008 | 12:25 AM
Dads90's Avatar
Dads90
I bought a can of color coded steel blue from PaintSctratch.com. Was going to repaint my mirrors, but tried them on the wheels and they came out nice. I polished with Mothers ( don't have the patience to work at this for longer than a hour per wheel). Just taped up the wheel with wide masking tape, exacta razor knifed out the slots and painted away. I was cool peeling off the tape when done. Actually could have used a second can, stretch it with one. Hit it with a clearcoat before removing the tape.
Old Jun 3, 2008 | 01:26 AM
lite blue's Avatar
lite blue
St. Jude Donor '12
I had a place called Wheel Techniques here in San Jose refinish my '91 wheels. They welded up some curb rash on all four, remachined the lips, stripped, blasted, painted, clear coated, and baked all four. Not cheap at about $160 per wheel, but they came out really nice. Here's a rear...
To Wheel refinishing
