1994 questions
Old Jun 5, 2008 | 11:16 AM
Rath150's Avatar
Rath150
7th Gear
Default 1994 questions
Newbie,
Bought a '94 3 years ago.
After about a year - started having w/ lights on clock and radio plate not going off all the time. It appeared drain the battery down badly if I didn't drive it at least once a week. Tech could not find the problem!
Second question: To a temporary solution, I thought I would put a new battery in. (As you might guess by now, I am not mechanically inclined)
One look and I closed the hood.
How do you get the battery out without tearing the car apart? It doesn't appear to be an easy way?
Paul
Old Jun 5, 2008 | 11:23 AM
User 020720's Avatar
User 020720
Sorry but I think you're 11 years too late.
Old Jun 5, 2008 | 11:26 AM
StanNH's Avatar
StanNH
You should repost this in the appropriate forum.
Old Jun 5, 2008 | 11:32 AM
ETHYL's Avatar
ETHYL
Open hood.the panel in front of the battery must be removed. There are a few screws underneath the panel that also need removing.when replacing the panel, make sure the panel is aligned correctly so the drivers door does not touch the edge.
Old Jun 5, 2008 | 11:34 AM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Moving to C4 general
Old Jun 5, 2008 | 11:37 AM
corvette-pilot's Avatar
corvette-pilot
There are a couple of screws in the fender well and some on the rocker area. One is kinda hidden near the door, you only need to loosen that one not take it out.
The lights ?? Maybe a bad door switch?
Old Jun 5, 2008 | 12:37 PM
pianoguy's Avatar
pianoguy
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old Jun 5, 2008 | 02:50 PM
Rath150's Avatar
Rath150
7th Gear
Sorry for getting in the wrong pew.
first time here.
Old Jun 5, 2008 | 03:48 PM
Red Dwarf's Avatar
Red Dwarf
first time here.
Glad you could make it. Don't worry about the seating.
Old Jun 8, 2008 | 10:24 AM
Rath150's Avatar
Rath150
7th Gear
I would like to thank all of you for your help!
I am not agile as I once was!!!
Took me awhile but gotter done.
Someone should shot the designers for some of the ways they lay things out!
Thanks again!
Old Jun 9, 2008 | 03:28 PM
NEVRL8T's Avatar
NEVRL8T
Thanks again!
You are gonna love the heater core and optispark.
Old Jun 9, 2008 | 05:24 PM
Eakster's Avatar
Eakster
Re the radio light staying on - this just started happening to mine too about 2 weeks ago. Usually some combination of key out/ key in, switching electrics on and off and opening the door and closing again sorts it out.
I don't know where the fault is - I had assumed I'd disturbed the wiring behind the head unit as I had it out recently and was poking around back there. I'm not worried as I'll be swapping out the HU soon, but would still be interested if you find out where the problem is.
Old Jun 9, 2008 | 05:34 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Newbie,
I have the same problem with my 93. It's the "door ajar" switch in the driver's door. Try this, turn off the ignition with the radio on and open the passenger's door. If the radio goes off then your driver's door ajar swith is shot or the little plunger in it is sticking.
To 1994 questions
