Vats Woes
Old Jul 8, 2008 | 03:04 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default vats
my 86 had 115,000 miles on it when this sort of thing started happening.
It turned out to be the starter brushes wore down to where the plastic brush holders expanded with the heat and kept the brushes from touching. every time it cooled off, it started right up.
If you still have problems, pull the starter.
my 2c
Old Jul 8, 2008 | 05:35 PM
All2kool's Avatar
All2kool
I've been momentarily stranded only once but I did have an '89 Trans Am that was hit or miss on the VATS. I disabled it, took but a few minutes. Here's how:
The VATS is controlled by the ECM. Changing locks (PITA) will only work if the key stays the same VATS number, of which there are 15 possibilities. If you install another lock, you'll need a new key cut with your VATS number. Disabling your VATS would be a solution. Go to a locksmith, they will test your key and be able to sell you a module to disable VATS. Remove the underdash panel on the driver side. You should easily spot a two-wire grouping, I believe yellow/orange/green and white, just to the right of the steering column (as it was on my 1989 TA). You should notice that it disconnects in the middle. Disconnect it, insert the module you got from the locksmith into the wire going towards the firewall. Voila, VATS is now disabled. The module will cost you $25 - and your car will never not start because of VATS. It actually took me longer to remove the underdash panel than it did to locate the wire and insert the module.
As for the security feature of VATS being disabled, only you will know. A car thief will likely pass your car by for another, like a Camry or Honda.
